I upgraded my machine a few days ago and now WiFi fails to start on 2 out of 3 cold boots. The kernel seems to initialize something, then the boot process chokes on everything that depends on networking. I have to turn the machine off and back on until it finally starts.
It would get to a prompt eventually if I wait long enough, but then there would be no WiFi and no internet, so I don’t even bother waiting anymore and I just reboot when it starts choking.
Does this happen to anyone else?
I’m not sure when the regression occurred exactly: I don’t exactly upgrade the machine religiously (precisely to avoid problems like that when it works well) and I haven’t paid attention to the kernel version number.
At the moment it’s 6.18.10 and the problem is still there.
It sounds like it might be that. But the issue says this at the end:
This is a regression since 6.17 and thus probably a bug somewhere. pcie_aspm=off is added by reform-tools until the culprit is found.
I assume this kernel parameter would be added silently during the update process, in which case it might be some other problem, because I upgraded 12 hours ago and it didn’t fix it.
I haven’t uploaded reform-tools with that change yet. It is sitting here:
Which platform/SoM/wifi are you on? I’d like to add another data point and potentially have another tester for when I find the time to bisect the kernel to find the culprit for this.
WiFi is whatever came with the machine when I ordered it. I haven’t checked and I’m at work right now. “Intel Wi-Fi 6-e Card” is what the order page says - and it says it’s required with the RK3588 if you want WiFi, and I wanted WiFi, so I suppose that’s what I have.
If this is too vague, I’ll check when I get home tonight
Out of curiosity, any pro/cons of pcie_aspm=off? I’m almost never on battery and almost always on the wall wart. So if it makes things a bit faster, I might just leave it there permanently even after the bug is fixed.
My NVMe SSD is still working, but my WiFi on the Headset/Switch Board 2.0 stopped working after rebooting with the last kernel update to the 6.18.x series. At first there were plenty of these messages in DMESG:
[ 10.802646] ath: phy0: Chip reset failed [ 10.802649] ath: phy0: Unable to reset channel, reset status -22 [ 10.814515] ath: phy0: DMA failed to stop in 10 ms AR_CR=0xffffffff AR_DIAG_SW=0xffffffff DMADBG_7=0xffffffff
after another reboot that changed to:
[ 35.066466] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.066490] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.170417] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.170441] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.274401] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.274422] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.378389] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.378410] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.482489] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.482510] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.586406] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.586425] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31 [ 35.690435] pcieport 0003:30:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 35.690453] pci_bus 0003:31: busn_res: [bus 31] end is updated to 31
had to disconnect that part of the headset/switch board to have it stop and will probably roll back to 6.17.x in the evening. Setting pcie_aspm=offdidn’t help much though.
Rollback to 6.17 in Guix System as well as booting the reform stock image didn’t change much, except that now the bridge configuration invalid errors are gone as well on both OS (had them as well on the stock OS today for two boots) but so is the WiFI card as it isn’t recognized anymore (no output in dmesg in any direction). I suspect hardware failure at this point, have to narrow down if its the cable between headset/switch board and SoM, the board itself, the wifi card etc.
It was (luckily just) a defective wifi card, got to test it on a different computer where it was erroneous as well, replaced it by a new atheros QCNFA222 card and everything’s up and working again - so the failing card hasn’t had anything to do with the kernel update after all except for timing.
