680x0 CPU - 680LC60 on A3660 with speedgeek chipset
RAM Configuration - 16MB (2x8MB SIMM)
Kickstart, AmigaOS Versions - 3.1.4.1
Monitor model - LG Ultragear 27GN850
Other Zorro cards - None
ZZ9000 FW & SW - 1.9.1 noautoboot
Other Info - Buster Rev 11, 4MB Romy, PIO2 IDE
Really enjoying my new ZZ9000, but I have one small issue when using installers - if I select Make New Drawer when I click Proceed from the New Drawer pop up the installer window blanks as below. This behaviour is the same with both P96 V2 and V3.x and all the V1.9.1 FWs - standard, noautoboot, nofast.
FYI, when I use the standard and no fast FW my Amiga gurus on cold boot, but then is fine on subsequent warm boots.
Hi Chewie, really weird issue. Is this bug really related to ZZ9000? What happenda if you run the same installer in Pal-Hires or even remove the drivers completly for ZZ9000, is the installer then working as it should?
