I had USB working great on 1.8. I followed these steps from the FB ZZ9000 page:
Step 1. Install Drivers and Package files.
Install ZZ9000 drivers using MNT’s Installer. Answer “Yes” when asked to install the USB Storage Driver. This will copy a file to Devs:ZZ9000USBStorage.device.
Unpack Fat95.lha make sure to copy the files under “L” directory and “C” to Sys:L and Sys:C if these binaries are not already there. You’ll need specifically L:fat95 to be present on your system.
Step 2. Create a Mountlist
Based on the Fat95 package, copy one of the mount files MS0 / MS1 and rename it to USB0 (for example).
Using a text Editor modify the mount list as follows (note I modified MS1 for testing):
/* MS1: fat95 PC file system for floppy #1 */
/* $VER: fat95 file system 3.06 (08-Aug-2002) by Torsten Jager */
FileSystem = L:fat95
Device = ZZ9000USBStorage.device
Unit = 0 /* change drive number here */
Flags = 0
LowCyl = 0
HighCyl = 0
Surfaces = 0 /* bootblock values have priority over these */
BlocksPerTrack = 1
Buffers = 20
BufMemType = 1
BootPri = 0
Stacksize = 4096
Priority = 5
GlobVec = -1
DosType = 0x46415401 /* enable ETD commands */
Save the file and exit the editor.
**Note.- Do not copy it over SYS:Devs/DOS drivers, since it can crash the computer at boot time. See step 5 below, and “7. Notes and Limitations” too.
Edit the Icon Tooltypes under “Icon” tab and add the following entries:
Activate=1
Device=ZZ9000USBStorage.device
Unit=0
L:fat95
Click [save], to save the Tooltypes you just set.
Step 3. Format and Partition the USB
Format a USB flash drive with the following specs.
Size: 4 GB (max).
FAT16 or FAT32.- both are supported.
If you have higher capacity USB flash disks only, execute the following procedure to delete its existing partition and create a 4 GB one.
Press Windows+R to open Run in a command prompt window.
DISKPART ↵
DISKPART> list disk ↵
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 40 GB 0 B
Disk 1 Online 7538 MB 0 B
Your USB is Disk 1 (7538 MB), select it:
DISKPART> select disk 1 ↵
Disk 1 is now the selected disk.
DISKPART> list part
Partition ### Type Size Offset
Partition 1 Primary 500 MB 1024 KB
DISKPART> clean ↵
DiskPart succeeded in cleaning the disk.
resize USB to 4000MB
DISKPART> create part primary size=4000
DiskPart succeeded in creating the specified partition.
DISKPART> active ↵
DiskPart marked the current partition as active.
Step 4. Format the USB flash.
**(You can use Linux / OS X if you want when formatting).
Step 5. Power Down the Amiga
Insert the newly formatted USB in the USB slot of the ZZ9000 card.
Power Up / Boot the Amiga.
Once it’s up and running double click on the USB0 device mount list you created in step 2.
A new drive will pop-up in Workbench.
Step 6.
- Additional Notes and Limitations.
Note.- Remember to power down / power up the Amiga every time you need to disconnect or reconnect the USB flash drive. Do not attempt to hot swap your USB device.
I’ve noticed that using Fat95 I’m limited to use 4GB partitions only. Using 8 GB partitions cause the system to get a Software Failure or apparently “mounting it” without popping any icon at all.
