ZZ9000 A2000 setup Question
  • Amiga model: A2000
  • 680x0 CPU: 68030/60
  • RAM Configuration: 128MB
  • Kickstart, AmigaOS Versions: 3.2.2.1
  • ZZ9000 Firmware version: -
  • ZZ9000 Driver version: 1.13
  • Monitor model: LG
  • Other Zorro cards: Dickie Olga
I got my new ZZ9000 last week and the audio board which I also orderd. I installed it and got the video working, network I am still working on, and the audio I am focused on right now.
The documentation that came with the sound card says I need to use AHI 4.18 which the link for it on MNT’s website; I used that link to download and brought over to my A2000. When I install it, during the installation it asks for which sound card you are installing, since there is no ZZ9000AX card listed there and the documentation doesn’t mention anything about this what am I supposed to choose?
Thanks,
IIRC you can choose any sound card to get through the installer, and then install the ZZ9000AX driver manually or with the ZZ9000 installer.
Ok.
When I select Paula and install the ZZ9000AX driver then reboot, and go into the AHI control panel in prefs I don’t see the ZZ9000AX, only Paula.
Does this mean the ZZ9000AX isn’t working?
