Hi Everyone,
My zz9000 doesn’t work with AmigaOS 3.2.2 roms/OS
I am using an A4000D with a rev6 68060 (full version.)
I am using v1.12.1 firmware and drivers.
There are no other Zorro cards, used in this system.
When I boot the card isn’t recognized by the drivers at all.
It does not show up in SysInfo, nor does it show up when booting into Early Startup Control.
Suggestions?
bob…
I believe the hardware works, as I am seeing normal amiga graphics modes via the HDMI port.
bob
And one last test, I inserted my BigRam+.
It isn’t recognized until I remove the zz9000. (before removing the zz9000, I tried BigRam is in any other slot - no joy.) I did use the NoFast version of the firmware, as well.
bob.
I use a configuration practically identical to yours, only with the 060 rev. 5, and I don’t seem to have any kind of problem.
- Amiga model: 4000TX
- 680x0 CPU: 68060 Rev. 5 A3660 rel 1.1
- RAM Configuration: 112+256
- Kickstart, AmigaOS Versions: 3.2.2-3.2.2
- ZZ9000 Firmware version:1.12.1
- ZZ9000 Driver version:1.12
Thanks for the message! I decided to try another slot, which ended up working. It appears that there is a fault with the lowest slot on my daughter card, for the A4000. “Old Computer Syndrome”.
Thanks again. Case Closed.
bob
