I’ve put my ZZ9000 into a 4000 fitted with an Apollo 4040 card.
At a cold boot, the scandoubler doesn’t work, If I Ctrl-A-A, then it works. If I use a ZZ screenmode, that appears to work and then if I go back to Amiga native output, the scandoubler is working. It appears starting a ZZ screenmode is somehow starting the scandoubler?
The interesting thing is, If I use an A3630 or A3640 card, it works fine.
I have noticed with the Apollo fitted, I don’t get the quick green flash on the LED on the Zynq board. I get white and red. With the other CPU cards, I get the green flash and it seems to mean the scandoubler is then going to work.
Is it possible that the card somehow doesn’t initialise with certain accelerators?
- Amiga model: A4000
- 680x0 CPU: 68040 (Apollo 4040 @ 40MHz)
- RAM Configuration: 2C/16F
- Kickstart, AmigaOS Versions: 3.2
- ZZ9000 Firmware version: 1.9
- ZZ9000 Driver version:
- Monitor model:
- Other Zorro cards:
