I’ve put my ZZ9000 into a Amiga 4000D fitted with an GVP T-rexII 060 card.
At a cold boot, only the scandoubler work, If I Ctrl-A-A, then ZZ9000 detected and works.
Is it possible that the card somehow doesn’t initialise with certain accelerators?
- Amiga model: Amiga 4000D
- 680x0 CPU: 68060/50 Mhz
- RAM Configuration: 128MB on accelerator
- Kickstart, AmigaOS Versions: 3.2.1, 3.2.1, P96 3.3.0
- ZZ9000 Firmware version: 1.11
- ZZ9000 Driver version: 1.11
- Monitor model:
- Other Zorro cards: none
