ZZ9000 + AX on Amiga2000 won't work with drivers, other issues
Hello,
I bought my ZZ9000 with ZZ9000AX in January from Alinea Computers
received it in February, and been trying to make it work ever since
Card has manufacture date of 2024-01-18
  • Amiga model: A1500 (mainboard it’s an A2000 rev 6.2)
  • 680x0 CPU: 68030 TF536 placed directly in the 68000 socket via a riser
  • RAM Configuration: 1Mb Chip, 12Mb fast: 4mb on TF536, 8Mb on GVP
  • Kickstart, AmigaOS Versions: 3.1 or 3.1.4, Workbench 3.1, AGS
  • ZZ9000 Firmware version: unknown
  • ZZ9000 Driver version: tried 1.21.1 and 1.13
  • Monitor model: compatible LCD which takes both SCART and HDMI
  • Other Zorro cards: GVP+8 with BlueSCSI
My Amiga passess all tests in in DiagROM 1.3 and AmigaTestKit
RGB output is perfect.
The issue I have is:
Card shows heavy artifacting, like jailbars and wrong graphics through HDMI from the start.
On Kickstart 3.1.4 I will get an early boot message stating the card is faulty and disabled
On Kickstart 3.1 it will load the system, but if I install drivers, on 1.13 it wil display yellow message that firmware needs to be at least 1.13 and then screen will go black
On drivers 1.12.1 it will say yellow message that firmware needs to be at least 1.9
This is regardless of what BOOT.BIN is on the SD card.
I’ve tried BOOT.BIN that came with the card, and almost every version for A2000 and a few for A3000 to absolutely no change.
I’ve tried a different microSD, a Samsung 2Gb one. Formatted FAT32 MBR. No joy / no change in behaviour. I have ordered a SanDisk 4Gb to try that as well.
To deal with the graphical corruption I tried:
Removed everything from my Amiga, left only the ZZ9000 and original 68000. This made no difference whatsoever, for the obvious reason could not proceed any further (no hdd, and even with hdd drivers need at least a 68020)
Disabling RAM on the GVP means I can no longer load AGS, but under WB3.1 issues persist.
I have had the ZZ9000 in every Zorro slot available, to no change.
I tried removing everything else form the Amiga, to no help.
I checked chips if they are all sitting correctly, including the fpga on zz9000
I tried fooling about with the video out on my mainboard, but it appears solid as fiddling with it has no effect on the on-sceen artifacts whatsoever.
Also once, after boot and during loading workbench, I got a red artifacted screen. RGB output was black during this. This only happened once so far.
I am suspecting the SD card slot on the ZZ9000 to be possibly at fault
here’s link showing the artifacting and also one of the yellow messages
Ignore the DH0 error displayed, it is when I disable GVP RAM and AGS fails to load.
ZZtop 1.1 fails to recognise card
ZZtop 1.11 displays absolute bollox :smiley:
Google Photos
Any help or guidance appreciated.
I am based in Scotland, between Edinburgh and Livingston.
UPDATE
TL:DR it was the factory supplied SD card after all, and the slot is dodgy
Managed to get this tested at a friend’s A2000, said friend already has a working zz9000
Well the card initially shat itself as well, until we swapped the SD cards
And voila! Card works perfectly.
So, no matter what we try, the SD that the card came with is not recognised.
Neither is the Samsung 2Gb card I tried. Both cards work perfectly fine in a PC.
I am now getting a SanDisk SD card as they have proven to be most reliable to be used in these homebrew devices.
Will update once I have this.
Saga continues
back at my Amiga2000, all the issues are happening again
We know the card worked flawlessly in another Amiga
And that my Amiga works flawlessly through RGB
Also the 68030 TF536 and GVP+8 work no issue
Where to look next… Buster chip? Wouldn’t that also affect the GVP+8 SCSI card?
Broken traces? Again. Shouldn’t there be other issues persisting?
Onboard jumper settings?
No idea where to go with this
You have 8MB of fast ram on zorro II, and I believe the RTG part of the ZZ9000 requires either 2 or 4MB of memory space, and there is only 8MB total on Zorro II. I think you have to disable at least half the memory on the GVP card to free space on the bus. Of course the GVP uses some of that ram to speed up transfers, but since you have much faster memory oh the TF536, you really don’t need much fast mem on zorro ii. Of course if you didn’t use the scsi part of the GVP then you should remove the card entirely.
I suspect your friend does not have 8MB of zorro ii fast ram in their system.
Did you get a chance to test it and if so did it help?
Hi
Yes actually tested today.
Partial success.
Drivers installed and seem to work and ZZtop recognized the card with firmware 1.13
But same screen corruption persists as in abovee screenshots - must be something wrong with my Amiga…
Edit zz9000 screenmode appear to work perfectly!!!
Just the pass through is shite
I will proceed with other testing
Have you checked if the RGB (DB23) or mono outputs also show it to figure out if it is a problem with the video slot, the ZZ9000 or the Amiga itself? I am wondering if denise is having issues.
RGB output is perfect, has been since the beginning. This is RGB-SCART
EDIT: during testing yesterday, I have found some strange anomalies, pointing the issue could be the MNT cable that links the video passthrough out to the card. As it was late in the night and I am working today I had to finish, but next week, or perhaps on Sunday I will focus on the cable to see if I can get the weird behaviour again.
“weird” means the artefacts started changing, sometimes worse sometimes less pronounced while same graphics were on screen. Also got horizontal noise instead of vertical artifact lines at some point.
