A2000 (NTSC), 2 meg chip (megachip), Vampire 500 v2+, Buddha IDE, OS 3.2 (ROM chip not really required because of vampire but it’s there).
The 1.9 firmware would not work for me - specifically, no P96 display would be visible, unless the nodma zz9000.card file was used. After which, the screen drawing is very very slow, pretty much making the system unusable.
No further attempt was made to test the usb or internet port.
I didn’t check all the native modes. NTSC hires laced did not work. Other modes did.
Hi, thanks for the bug report. The bad performance is a new bug that I also noticed a few days ago. Please test this new pre-release firmware and tell me if the problem is gone:
With the Vampire card in my Amiga (and Buddha IDE), the computer boots to a green screen.
2nd test:
Removing the Vampire and using a 68000, the computer boots from both floppy or the Buddha. I even installed an AdRam 2080 RAM card. Computer works. Native NTSC high-res laced screen mode works. So does PAL high-res laced.
LoadModuleError: Some devices are validating, reboot aborted
This part of the boot sequence from OS 3.2. By default, the vampire has a resident modified kickstart 3.1 in its flashmemory. So the boot sequence tries to load 3.2 resident. I never saw this error before.
There is another problem: When in a native screen mode, the display turns on and off.
