Hi
I’m trying to get my ZZ9000 to connect to my router. Using roadshow, I can see in the log that it just times out waiting for a DHCP answer. If I specify static address, it looks like it’s connected but the router says nothing is using that IP and I can’t even ping the gateway from Amiga
It was working, then I reinstalled Workbench and it stopped.
I’ve also tried AmiTCP (as EasyNet) which says it’s connected (static IP) but nothing transfers. Tried MiamiDX, similar - “Online” but cannot ping.
If I swap to a USB Ethernet adaptor on the Freeway, it works fine - DHCP via Roadshow, downloads at decent speed etc. So it feels like an issue with the card, or with ZZ9000net.device
Are there any diagnostic tools?
- Amiga model: A4000
- 680x0 CPU: 68060
- RAM Configuration: 2+16MB+ZZ9000
- Kickstart, AmigaOS Versions: 3.2.1
- ZZ9000 Firmware version: 1.9
- ZZ9000 Driver version: 1.9
- Monitor model: n/a
- Other Zorro cards: Freeway Pro
