RAM Configuration: 16MB Fast onboard, 128MB BFG9060
Kickstart, AmigaOS Versions: 3.2.1
ZZ9000 Firmware version: 1.11 without RAM and autoboot
ZZ9000 Driver version:
Monitor model:
Other Zorro cards: FastATA 4000
When using the ZZ9000 with kickstart 3.2 the system seems to be stuck in reset, power LED doesn’t get bright.
Works with Kickstart 3.1, so I guess Kick 3.2 does something different on startup. Reset via keyboard doesn’t change anything.
It seems that I damaged the ZZ9000, it isn’t even recognized in the early boot menu. Could I send it in for you to have a look at it? Of course I’d pay for the service.
The whole issue has been solved. When I took my A4000 apart I accidentally lifted the sandwiched board on the ZZ9000 just a little bit which caused it to partially lose contact. Works perfectly now, even with Kickstart 3.2
