ZZ9000 Scandoubler Issue
My scandoubler is not running with the update of 1.11 any ideas by scanboubler I mean the little card that comes with the zz9000
If you want to ask a technical support question, please include the following details.
  • Amiga model:
  • 680x0 CPU:
  • RAM Configuration:
  • Kickstart, AmigaOS Versions:
  • ZZ9000 Firmware version:
  • ZZ9000 Driver version:
  • Monitor model:
  • Other Zorro cards:
Make that mine too had to go back to 1.9 firmware. my spec is A4000 with cyberstorm Mk2 060 rev 6 128mb ram plus 16mb on the motherboard kick start is 3.2 os 3.2.1 I had the 1.11 firmware and drivers installed other card is the Elbox IDE Monitor 34" Ultra wide screet AOC.
OK now done a little more turns out my AX has not been working right it is clicking alot with the sound and it seems when enabled in AHI wont let games load. I have had to come off version 1.11 as it does not like running games on my machine
