- Amiga model: 4000
- 680x0 CPU: 060
- RAM Configuration: 16/256
- Kickstart, AmigaOS Versions: 3.2 / 3.2.1
- ZZ9000 Firmware version: 1.11
- ZZ9000 Driver version: 1.11
- Monitor model:
- Other Zorro cards: fastata 4000
Using axmp3 it says it in the cli it’s using int6. In snoopdos it says it’s failing at using int2. I tried to change the position of jumper j4 but then I just got a black screen.
