My ZZ9000 seems to be working fine. However, when I run the ZZTop Bus Test, I get a message toward the end indicating the result is not as expected (0x7a09 instead of 0xffff). See below. Is this an issue?
Thank you,
Wayne
zz_perform_memtest...
Done. 0 errors.
zz_perform_memtest_rand...
`-- Test 0x100000 0/1024...
`-- Test 0x100000 128/1024...
`-- Test 0x100000 256/1024...
`-- Test 0x100000 384/1024...
`-- Test 0x100000 512/1024...
`-- Test 0x100000 640/1024...
`-- Test 0x100000 768/1024...
`-- Test 0x100000 896/1024...
Done. 0 errors.
zz_perform_memtest_delaywrites...
Done. Result: 0x7a09 (should be: 0xffff)
zz_perform_memtest_fpgareg...
Done. Result: 7a09
- Amiga model: A2000
- 680x0 CPU: 68030 @ 50 MHz (TF536)
- RAM Configuration: 1MB chip, 64MB fast
- Kickstart, AmigaOS Versions: Kickstart 3.1.4, AmigaOS 3.1.4
- ZZ9000 Firmware version: 1.11 (Zorro II, 2MB)
- ZZ9000 Driver version: 1.11
- Monitor model: Vizio VA19L
- Other Zorro cards: Bridgeboard 2286
