After using the setup wizard (great experience), I tried to install gcc with:
$ apt update
$ apt install build-essential
This resulted in an error message related to a bug in binutils, presumably #1074111 - [arm64] boot stops at 'Starting kernel ...' without any further output when kernel built with recent binutils - Debian Bug report logs
Is there a simple way to install a previous version of gcc (and binutils)?
josch
July 1, 2024, 10:28pm
2
I’m the author of that bug. You probably mean to install the package build-essential. You can retrieve past versions of packages from snapshot.d.o but in case of binutils, you will require quite a few additional packages for this to work out due to versioned dependencies. The result is not for the faint of heart:
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/binutils_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/libbinutils_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/binutils-aarch64-linux-gnu_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/binutils-arm-linux-gnueabihf_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/binutils-common_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/libctf0_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240321T160517Z/pool/main/b/binutils/libgprofng0_2.42-4_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/gcc-13-aarch64-linux-gnu_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/gcc-13_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/g%2B%2B-13_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/libstdc%2B%2B-13-dev_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/cpp-13_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/cpp-13-aarch64-linux-gnu_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/g%2B%2B-13-aarch64-linux-gnu_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/gcc-13-base_13.2.0-25_arm64.deb
wget http://snapshot.debian.org/archive/debian/20240515T144351Z/pool/main/g/gcc-13/libgcc-13-dev_13.2.0-25_arm64.deb
apt-get install ./binutils-arm-linux-gnueabihf_2.42-4_arm64.deb ./binutils-common_2.42-4_arm64.deb ./binutils_2.42-4_arm64.deb ./libbinutils_2.42-4_arm64.deb ./binutils-aarch64-linux-gnu_2.42-4_arm64.deb ./libctf0_2.42-4_arm64.deb ./libgprofng0_2.42-4_arm64.deb ./gcc-13-aarch64-linux-gnu_13.2.0-25_arm64.deb ./gcc-13_13.2.0-25_arm64.deb ./g++-13_13.2.0-25_arm64.deb ./libstdc++-13-dev_13.2.0-25_arm64.deb ./cpp-13_13.2.0-25_arm64.deb ./cpp-13-aarch64-linux-gnu_13.2.0-25_arm64.deb ./g++-13-aarch64-linux-gnu_13.2.0-25_arm64.deb ./gcc-13-base_13.2.0-25_arm64.deb ./libgcc-13-dev_13.2.0-25_arm64.deb
It might be easier to work inside a chroot until that binutils bug is fixed.
Hi josch,
Yes, typos are now fixed.
Great, will give it a try.
Thanks a lot!
Tried the above commands, which broke Wi-Fi. See WiFi gone after reboot - #3 by minute for an explanation and fix.
For future reference, to install gcc , this now works:
$ sudo apt update
$ sudo apt upgrade
$ sudo apt install build-essential
