No battery status and brightness control with trixie-backports
This is the actual error. So I wonder: what is /dev/root supposed to be?
Yes, you can select 6.12.94 in the u-boot menu and if that works, you can start investigating what happens here. But before you destroy evidence by running update-initramfs as suggested by that forum post, could you try and find out why this problem happened in the first place? Maybe there is a bug that we can fix to avoid that others run into the same problem.
If you cannot boot into 6.12.94 then you can perform the same diagnostic by booting from a vanilla sd-card image and getting access to your system on SSD by running reform-rescue-shell.
The interesting output would be:
$ cat /etc/fstab
$ sudo unmkinitramfs /boot/initrd.img-7.1.3-mnt-reform-arm64 /tmp/initramfs
$ cat /tmp/initramfs/conf/conf.d/default_root
$ sudo reform-check
i’ll try that tomorrow and get as much info as I can then. for now I’m closing out my day. i’ll likely be back in ~12-16 hours.
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo cat /etc/fstab
#LABEL=reformsdroot / auto errors=remount-ro 0 1
#LABEL=reformsdboot /boot auto errors=remount-ro 0 1
#UUID=4665549e-3b8d-436d-90b2-98ac34a013f4 none swap sw 0 0
/dev/reformvg/root / auto errors=remount-ro 0 1
/dev/mmcblk1p1 /boot auto errors=remount-ro 0 1
#folowing entries are for Octobers-Crypt NAS server.
cut off due to privacy but the only lines are for my NAS, there’s 3 more
unmkinitramfs: /boot/initrd.img-7.1.3-mnt-reform-arm64: No such file or directory
that said, there was an error i found last time where it refused to properly set things up
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo apt upgrade
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
  4 not fully installed or removed.
  Space needed: 0 B / 1,778 GB available
Continue? [Y/n]
as seen there (chose n for now)
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo cat /tmp/initramfs/conf/conf.d/default_root
cat: /tmp/initramfs/conf/conf.d/default_root: No such file or directory
i don’t know how or why it isn’t giving output, but that may be because the above command about the initramfs failed?
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo reform-check
I: reform.debian.net is configured as a mirror in /etc/apt/sources.list.d
I: Assuming reform.debian.net stable mirror for this script
I: If this is incorrect, you can set the mirror to its default by re-running this script with --mirror=mntre.com
I: Contents of /proc/device-tree/model: MNT Pocket Reform with BPI-CM4 Module
I: `uname -a` output: Linux The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of 6.12.94-mnt-reform-arm64 #1 SMP Debian 6.12.94-1+reform20260807T053513Z (2026-08-07) aarch64 GNU/Linux
E: Cannot get version of linux-image-mnt-reform-arm64 as it is not installed
I: Version of reform-tools: 1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1
I: Version of system image: System Image v5: 2025-08-27
I: Version of system controller firmware: 20260808
I: Version of keyboard firmware: 20260808
I: Version of Pocket Reform panel: 2
W: /sys/bus/spi/drivers/reform2_lpc/spi1.0/firmware does not exist -- is the reform2_lpc module loaded?
E: expected u-boot version string to start with upstream version but got: 2024.04-dirty
I: Contents of /proc/device-tree/chosen/u-boot,version: 2024.04-dirty
W: Unable to parse contents of /proc/device-tree/chosen/u-boot,version -- U-Boot too old?
I: Mount source of /boot: /dev/mmcblk1p1 (eMMC)
I: MNT Reform Desktop meta-package is not installed: reform-desktop-full
I: Depends of reform-desktop-full is not installed: alsa-ucm-conf
I: Depends of reform-desktop-full is not installed: engrampa
I: Depends of reform-desktop-full is not installed: espeak-ng
I: Depends of reform-desktop-full is not installed: firefox-esr
I: Depends of reform-desktop-full is not installed: gnome
I: Depends of reform-desktop-full is not installed: gnome-shell-extension-dashtodock
I: Depends of reform-desktop-full is not installed: hyfetch
I: Depends of reform-desktop-full is not installed: mesa-vulkan-drivers
I: Depends of reform-desktop-full is not installed: mpv
I: Depends of reform-desktop-full is not installed: nfs-common
I: Depends of reform-desktop-full is not installed: ptyxis
I: Depends of reform-desktop-full is not installed: rtkit
I: Depends of reform-desktop-full is not installed: sway
I: Depends of reform-desktop-full is not installed: thunar
I: Depends of reform-desktop-full is not installed: vulkan-tools
E: linux-image-mnt-reform-arm64 is not installed
E: linux-headers-mnt-reform-arm64 is not installed (cannot compile reform2_lpc.ko DKMS module for battery status)
I: /boot/vmlinuz-7.1.3.1-mnt-reform-arm64 does not belong to any installed kernel package
E: mnt_sc is not loaded (likely broken: battery status, brightness control and poweroff)
E: /usr/lib/modules/6.12.94-mnt-reform-arm64/kernel/drivers/firmware/mnt-sc.ko{.xz} does not exist
E: /sys/class/power_supply/BAT0 is missing -- reform2_lpc module not loaded?
 + fbcon=rotate:3
 + fbcon=font:TER16x32
E: /boot/boot.scr doesn't reference the currently running kernel
I: Install the package shellcheck for checking /boot/boot.scr for problems
E: Failed to fetch https://source.mnt.re/reform/reform-a311d-uboot/-/jobs/artifacts/2026-04-09/raw/meson-g12b-bananapi-cm4-mnt-pocket-reform-flash.bin?job=build  Temporary failure resolving 'source.mnt.re'
E: Download Failed
E: download of https://source.mnt.re/reform/reform-a311d-uboot/-/jobs/artifacts/2026-04-09/raw/meson-g12b-bananapi-cm4-mnt-pocket-reform-flash.bin?job=build failed
it looks like it refused to build the right thing, and put itself into a broken state because it wasn’t able to build the thing, like not building that one module i mentioned back here
didn’t have a graceful failure state (like i kind of assumed it would) so we wind up with a sort of installed 7.1.3 kernel but not really installed because it threw a fit. at least that’s my best guess. should i uninstall the 7.1.3 kernel packages completely, and restart sudo apt update and sudo apt upgrade?
Thank you. I didn’t understand where /dev/root comes from. I now read some initramfs-tools code and it seems to be the fallback if no root device was otherwise chosen. So this is the likely reason why you cannot boot and it explains your error message during boot.
The file is probably named /boot/initrd.img-7.1.3.1-mnt-reform-arm64. Can you try again with that filename? If that does not exist either, which files do you have in /boot?
What was the error? If the 4 not fully installed packages are your kernel, then that would explain why you cannot boot and making it install properly might fix your issue.
Choose Y and copypaste the error message (if any).
You ran that command after you successfully extracted the initramfs, right?
If you didn’t extract the initramfs to /tmp/initramfs then yes, that directory will not exist.
This is a problem.
This is a problem.
No. You don’t have the kernel meta packages installed. This has nothing to do with not building the DKMS drivers.
Lucie already advised you to remove the qcacld2 dkms package which creates this problem. You don’t need it on rk3588.
The problem is created because you are trying to use the qcacld2 package from Trixie with a kernel from trixie-backports. The code in trixie has no idea about a kernel from the future. You can also upgrade the qcacld2 package to the version from trixie-backports but there is no reason to waste cpu cycles on compiling a module your machine does not need.
No, you should do the opposite. Please install kernel packages and remove the dkms driver your system does not need.
Can you give me the output of the following command please:
dpkg-query --showformat '${db:Status-Status}\n' --show linux-image-mnt-reform-arm64
strangely, nothing for that kernel image.
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:/boot$ ls -la
total 123908
drwxr-xr-x  5 root root     4096 Aug  9  2026 .
drwxr-xr-x 18 root root     4096 Aug  9  2026 ..
-rw-r--r--  1 root root     5645 Aug  9  2026 boot.scr
-rw-r--r--  1 root root     5610 Aug  7  2026 boot.scr.bak
-rw-r--r--  1 root root   335666 Aug  7  2026 config-6.12.94-mnt-reform-arm64
-rw-r--r--  1 root root   354959 Aug  7  2026 config-7.1.3.1-mnt-reform-arm64
lrwxrwxrwx  1 root root       83 Aug  9  2026 dtb -> dtbs/7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
lrwxrwxrwx  1 root root       83 Aug  9  2026 dtb-6.12.94-mnt-reform-arm64 -> dtbs/6.12.94-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
lrwxrwxrwx  1 root root       83 Aug  9  2026 dtb-7.1.3.1-mnt-reform-arm64 -> dtbs/7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
drwxr-xr-x 10 root root     4096 Aug  9  2026 dtbs
drwxr-xr-x  2 root root     4096 Aug  9  2026 extlinux
-rw-r--r--  1 root root  1592320 Aug  9  2026 flash.bin
-rw-r--r--  1 root root 51229994 Aug  9  2026 initrd.img-6.12.94-mnt-reform-arm64
drwx------  2 root root    16384 Aug 27  2025 lost+found
-rw-r--r--  1 root root   102464 Aug 27  2025 ls1028a-mhdpfw.bin
-rw-r--r--  1 root root       83 Aug  7  2026 System.map-6.12.94-mnt-reform-arm64
-rw-r--r--  1 root root       98 Aug  7  2026 System.map-7.1.3.1-mnt-reform-arm64
-rw-r--r--  1 root root 32391680 Aug  7  2026 vmlinuz-6.12.94-mnt-reform-arm64
-rw-r--r--  1 root root 40835584 Aug  7  2026 vmlinuz-7.1.3.1-mnt-reform-arm64
trying this now, got the same error about ezurio-qcacld-2.0-dkms which i’m removing now. which as i write this i just alt tabbed back to the uart and it seems to have caused a domino effect of apt automatically fixing everything. gonna reboot and report back now, but here’s the logs
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo apt remove ezurio-qcacld-2.0-dkms
REMOVING:
Summary:
  Upgrading: 0, Installing: 0, Removing: 1, Not Upgrading: 0
  Freed space: 29.0 MB
Continue? [Y/n] y
(Reading database ... 437346 files and directories currently installed.)
Removing ezurio-qcacld-2.0-dkms (0.0~git20240408.aa96a9f+dfsg-5+reform20250623T081239Z+1) ...
Module ezurio-qcacld-2.0/0.0~git20240408.aa96a9f+dfsg for kernel 6.12.94-mnt-reform-arm64 (aarch64):
Before uninstall, this module version was ACTIVE on this kernel.
Deleting /lib/modules/6.12.94-mnt-reform-arm64/updates/dkms/qcacld2.ko.xz
Running depmod..... done.
Deleting module ezurio-qcacld-2.0/0.0~git20240408.aa96a9f+dfsg completely from the DKMS tree.
Setting up linux-image-7.1.3.1-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260807T053513Z) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-7.1.3.1-mnt-reform-arm64
I: skipping reform_set_root in favour of flash_kernel_set_root
Using DTB: amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
Installing /usr/lib/linux-image-7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb into /boot/dtbs/7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
Taking backup of meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb.
Installing new meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb.
flash-kernel: deferring update (trigger activated)
/etc/kernel/postinst.d/zz-flash-kernel:
/usr/share/kernel/postinst.d/zz-reform-bootspec:
I: Now running: /usr/share/kernel/postinst.d/zz-reform-bootspec 7.1.3.1-mnt-reform-arm64 /boot/vmlinuz-7.1.3.1-mnt-reform-arm64
I: with DEB_MAINT_PARAMS=configure
I: installed /boot/loader/entries/meson-g12b-bananapi-cm4-mnt-pocket-reform-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs6490-mnt-pocket-reform-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs8550-mnt-pocket-reform-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/rk3588-mnt-pocket-reform-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/imx8mp-mnt-pocket-reform-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/imx8mq-mnt-reform2-hdmi-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/meson-g12b-bananapi-cm4-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/fsl-ls1028a-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs6490-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs8550-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/rk3588-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/rk3588-mnt-reform2-dsi-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/imx8mp-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/imx8mq-mnt-reform2-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs6490-mnt-reform-next-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/qcs8550-mnt-reform-next-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/rk3588-mnt-reform-next-7.1.3.1-mnt-reform-arm64.conf
I: installed /boot/loader/entries/rk3588-mnt-station-7.1.3.1-mnt-reform-arm64.conf
/etc/kernel/postinst.d/zz-reform-tools:
I: Now running: /etc/kernel/postinst.d/zz-reform-tools 7.1.3.1-mnt-reform-arm64 /boot/vmlinuz-7.1.3.1-mnt-reform-arm64
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs6490-mnt-pocket-reform.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs6490-mnt-pocket-reform.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs8550-mnt-pocket-reform.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs8550-mnt-pocket-reform.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/rockchip/rk3588-mnt-pocket-reform.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/rockchip/rk3588-mnt-pocket-reform.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/freescale/imx8mp-mnt-pocket-reform.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/freescale/imx8mp-mnt-pocket-reform.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/freescale/imx8mq-mnt-reform2-hdmi.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/freescale/imx8mq-mnt-reform2-hdmi.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/amlogic/meson-g12b-bananapi-cm4-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/freescale/fsl-ls1028a-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/freescale/fsl-ls1028a-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs6490-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs6490-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs8550-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs8550-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/rockchip/rk3588-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/rockchip/rk3588-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/rockchip/rk3588-mnt-reform2-dsi.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/rockchip/rk3588-mnt-reform2-dsi.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/freescale/imx8mp-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/freescale/imx8mp-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/freescale/imx8mq-mnt-reform2.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/freescale/imx8mq-mnt-reform2.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs6490-mnt-reform-next.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs6490-mnt-reform-next.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/qcom/qcs8550-mnt-reform-next.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/qcom/qcs8550-mnt-reform-next.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/rockchip/rk3588-mnt-reform-next.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/rockchip/rk3588-mnt-reform-next.dtb
I: copying /usr/lib/modules/7.1.3.1-mnt-reform-arm64/dtb/rockchip/rk3588-mnt-station.dtb to /boot/dtbs/7.1.3.1-mnt-reform-arm64/rockchip/rk3588-mnt-station.dtb
/etc/kernel/postinst.d/zz-u-boot-menu:
P: Checking for EXTLINUX directory... found.
P: Writing config for vmlinuz-7.1.3.1-mnt-reform-arm64...
P: Writing config for vmlinuz-6.12.94-mnt-reform-arm64...
P: Updating /boot/extlinux/extlinux.conf...
Setting up linux-headers-7.1.3.1-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260807T053513Z) ...
Setting up linux-image-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260807T053513Z) ...
Setting up linux-headers-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260807T053513Z) ...
Processing triggers for flash-kernel (3.110~bpo13+1+reform20260528T082855Z~bpo13+1) ...
flash-kernel: installing version 7.1.3.1-mnt-reform-arm64
Generating boot script u-boot image... done.
Taking backup of boot.scr.
Installing new boot.scr.
Summary:
edit: rebooted and everything works automagically. seems that one package was causing the system to hang and just, not work. uninstalling it worked fine.
ok well one error that seems to not be going anywhere, i’m getting no display out with the main screen. i get output to the microHDMI with an adapter until i enter my encryption password. then it cuts out and doesn’t come back. that said, everything was working fine before when i first booted. (battery, brightness, etc)
i can blindly sudo apt update if needed (since i already disconnected the UARTs frustratingly)
got UARTs back on and am just not gonna take them off for now.
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ dpkg-query --showformat '${db:Status-Status}\n' --show linux-image-mnt-reform-arm64
installed
tried sudo unmkinitramfs /boot/initrd.img-7.1.3-1-mnt-reform-arm64 /tmp/initramfs again and then ran cat /tmp/initramfs/conf/conf.d/default_root and got this
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:/boot$ cat /tmp/initramfs/conf/conf.d/default_root
ROOT="/dev/reformvg/root"
also ran the reform check and got this out
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:/boot$ sudo reform-check
I: Version of linux-image-mnt-reform-arm64: 7.1.3-1~bpo13+1+reform20260812T225358Z
[  789.896235] SCSI subsystem initialized
I: Recommends of reform-desktop-minimal is not installed: ezurio-qcacld-2.0-dkms
E: the currently running kernel is not the one provided by linux-image-mnt-reform-arm64
 + fbcon=rotate:3
E: ACL of /dev/dri/renderD128 does not contain an entry for nebula -- missing access means no hardware rendering for non-root users
E: Download Failed
which i think this line explains what the error is E: ACL of /dev/dri/renderD128 does not contain an entry for nebula -- missing access means no hardware rendering for non-root users so yeah.
also reinstalled kernel and reform tools to be safe and then ran a reform check
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo apt update
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://security.debian.org/debian-security trixie-security InRelease
Hit:3 http://deb.debian.org/debian trixie-updates InRelease
Get:4 https://repo.librewolf.net librewolf InRelease [5,665 B]
Hit:5 https://reform.debian.net/debian trixie-backports InRelease
Hit:6 https://repo.waydro.id trixie InRelease
Fetched 5,665 B in 1s (3,801 B/s)
All packages are up to date.
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo apt --reinstall install linux-image-mnt-reform-arm64 reform-tools
Summary:
  Upgrading: 0, Installing: 0, Reinstalling: 2, Removing: 0, Not Upgrading: 0
  Download size: 1,684 B / 3,818 kB
Get:1 https://reform.debian.net/debian trixie-backports/main arm64 linux-image-mnt-reform-arm64 arm64 7.1.3-1~bpo13+1+reform20260812T225358Z [1,684 B]
Fetched 1,684 B in 1s (1,242 B/s)
(Reading database ... 436602 files and directories currently installed.)
Preparing to unpack .../linux-image-mnt-reform-arm64_7.1.3-1~bpo13+1+reform20260812T225358Z_arm64.deb ...
Unpacking linux-image-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260812T225358Z) over (7.1.3-1~bpo13+1+reform20260812T225358Z) ...
Preparing to unpack .../reform-tools_1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1_all.deb ...
Unpacking reform-tools (1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1) over (1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1) ...
Setting up linux-image-mnt-reform-arm64 (7.1.3-1~bpo13+1+reform20260812T225358Z) ...
Setting up reform-tools (1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1) ...
I: Now running: /usr/share/kernel/postinst.d/zz-reform-tools 6.12.94-mnt-reform-arm64 /boot/vmlinuz-6.12.94-mnt-reform-arm64
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dtb
W: no dtb for qcom/qcs6490-mnt-pocket-reform.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
W: no dtb for qcom/qcs8550-mnt-pocket-reform.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-pocket-reform.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-pocket-reform.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/freescale/imx8mp-mnt-pocket-reform.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/freescale/imx8mp-mnt-pocket-reform.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/freescale/imx8mq-mnt-reform2-hdmi.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/freescale/imx8mq-mnt-reform2-hdmi.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-reform2.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/amlogic/meson-g12b-bananapi-cm4-mnt-reform2.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/freescale/fsl-ls1028a-mnt-reform2.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/freescale/fsl-ls1028a-mnt-reform2.dtb
W: no dtb for qcom/qcs6490-mnt-reform2.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
W: no dtb for qcom/qcs8550-mnt-reform2.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-reform2.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-reform2.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-reform2-dsi.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-reform2-dsi.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/freescale/imx8mp-mnt-reform2.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/freescale/imx8mp-mnt-reform2.dtb
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/freescale/imx8mq-mnt-reform2.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/freescale/imx8mq-mnt-reform2.dtb
W: no dtb for qcom/qcs6490-mnt-reform-next.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
W: no dtb for qcom/qcs8550-mnt-reform-next.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
W: no dtb for rockchip/rk3588-mnt-reform-next.dtb in /usr/lib/linux-image-6.12.94-mnt-reform-arm64 -- skipping...
I: copying /usr/lib/linux-image-6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-station.dtb to /boot/dtbs/6.12.94-mnt-reform-arm64/rockchip/rk3588-mnt-station.dtb
I: Now running: /usr/share/kernel/postinst.d/zz-reform-tools 7.1.3.1-mnt-reform-arm64 /boot/vmlinuz-7.1.3.1-mnt-reform-arm64
Could not execute systemctl:  at /usr/bin/deb-systemd-invoke line 148.
Processing triggers for initramfs-tools (0.148.4) ...
Processing triggers for man-db (2.13.1-1) ...
Processing triggers for libglib2.0-0t64:arm64 (2.84.4-3~deb13u3) ...
Processing triggers for u-boot-menu (4.2.4) ...
 + fbcon=rotate:3
W: eMMC does not contain latest bootloader
reform-flash-bootloader emmc
I: note that updating the bootloader on eMMC on your platform is not without risk!
so yeah.
(also if i sound cold i’m not tryna be just, really wanting this fixed, and going full “analytical mind”)
oh and as for the kernel errors in reform-check, i booted the previous one since the new one’s video out wasn’t working (though the old one wasn’t now since i ran a sudo apt update and upgrade earlier)
This explains why your system wasn’t doing anything before. You cannot boot without an initramfs.
But didn’t you write in your next message that you don’t have display output?
So you are saying it worked fine first, you did nothing, then rebooted and that boot didn’t work?
That’s too late. It would’ve been valuable to have the output of that command when you were still in the state where qcacld2 had messed up your installation.
Too late. The output of that command was for the other problem you have. Now display is missing which has nothing to do with this file. It would’ve been useful to have the output of this command back when the qcacld2 situation was still unresolved.
You booted into kernel 6.12.94 not into 7.1.3
This needs to be investigated. Can you show me your /boot/extlinux/extlinux.conf
This too. What is the output of this command:
grep "setenv fk_kvers" /boot/boot.scr
Maybe. But there are other more glaring problems for now.
You did not. You re-installed linux-image-mnt-reform which is a meta-package and does not actually contain any data.
Don’t run reform-check right after you re-installed your kernel. You should first see if re-installing the kernel actually changed what kernel is getting booted and for that you have to reboot first.
starting post to say that i’ll wait for your next reply before doing anything, including rebooting or anything.
bingo
ok, how can i fix that?
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:/boot/extlinux$ cat extlinux.conf
## /boot/extlinux/extlinux.conf
## IMPORTANT WARNING
## The configuration of this file is generated automatically.
## Do not edit this file manually, use: u-boot-update
default l0
menu title U-Boot menu
prompt 1
timeout 1
label l0
	menu label Debian GNU/Linux 13 (trixie) 7.1.3.1-mnt-reform-arm64
	linux /vmlinuz-7.1.3.1-mnt-reform-arm64
	initrd /initrd.img-7.1.3.1-mnt-reform-arm64
	fdt /dtb-7.1.3.1-mnt-reform-arm64
	append   ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ${bootargs} console=tty1
label l0r
	menu label Debian GNU/Linux 13 (trixie) 7.1.3.1-mnt-reform-arm64 (rescue target)
	append   ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ${bootargs} console=tty1 single
label l1
	menu label Debian GNU/Linux 13 (trixie) 6.12.94-mnt-reform-arm64
	linux /vmlinuz-6.12.94-mnt-reform-arm64
	initrd /initrd.img-6.12.94-mnt-reform-arm64
	fdt /dtb-6.12.94-mnt-reform-arm64
label l1r
	menu label Debian GNU/Linux 13 (trixie) 6.12.94-mnt-reform-arm64 (rescue target)
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:/boot/extlinux$ grep "setenv fk_kvers" /boot/boot.scr
grep: /boot/boot.scr: binary file matches
my bad, forgot about that. would it even help if i reinstall the kernel image?
ok, should i go ahead and do that? if not what should i do?
also to clarify: before this i had updated, then rebooted, then it stopped display out, causing the display out post, and then this was a separate boot where i booted old kernel to try and fix things.
That’s too many reboots and posting things from states other than the ones I thought they were from and re-installing things and running commands where I didn’t expect you to run them. We need to get back to zero.
When you boot right now, which kernel is booting?
if i reboot, it defaults to 7.1.3. would you like me to try to boot that now and post UART?
Do a normal boot. Describe what happens with your display and yes, please post the full uart output and reform-check output from that boot.
here’s the full UART from the top to where it hangs waiting for encryption password. going to enter password blindly and then log in
[16:35:06.254] tio v2.7
[16:35:06.254] Press ctrl-t q to quit
[16:35:06.255] Connected
G12B:BL:6e7c85:2a3b91;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;0.
        bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 153604
BL2 Built : 19:23:21, Sep 18 2020. g12b g9fde858 - gongwei.chen@droid11-sz
Board ID = 12
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0002a140
eMMC boot @ 0
sw8 s
board id: 12
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
Get wrong ddr fw magic! Error!!
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
 NO find ddr boot_info from eMMC
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
LPDDR4 probe
LPDDR4_PHY_V_0_1_22-Built : 14:57:26, Sep  1 2020. g12b g3c95fed - gongwei.chen@droid11-sz
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
INFO : End of CA training
INFO : End of initialization
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of read delay center optimization
Check phy result
INFO : End of write delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 0000001c 0000001d 0000001c 0000001d 0000001c 0000001c 0000001b 0000001e 0000001b 0000001c 0000001d 0000001b 0000001c 0000001b 0000001d 0000001c 0000001e 0000001b 0000001c 0000001e 0000001c 0000001c 0000001c 0000001d 0000001d 0000001d 0000001c 0000001d 0000001c 0000001c 0000001d 0000001a dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004
 dram_vref_reg_value 0x 0000004e
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 2048MB
DMC_DDR_CTRL: 00e00024DDR size: 3928MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 414
result report
boot times 0Enable ddr reg access
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x00109400, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12b_v1.1.3390-6ac5299 2019-09-26 14:10:05 luan.yuan@droid15-sz]
OPS=0x10
ring efuse init
chipver efuse init
29 0b 10 00 01 1e 1a 00 00 0f 36 38 34 55 30 50
[0.018961 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:58:17, May 22 2019
NOTICE:  BL31: G12A normal boot!
ERROR:   Error initializing runtime service opteed_fast
<debug_uart>
U-Boot 2024.04-dirty (Oct 11 2024 - 20:36:25 +0000)bpi-cm4-mnt-pocket-reform
Model: MNT Pocket Reform with BPI-CM4 Module
SoC:   Amlogic Meson G12B (A311D) Revision 29:b (10:2)
DRAM:  1 GiB (effective 3.8 GiB)
Core:  404 devices, 30 uclasses, devicetree: separate
MMC:   sd@ffe03000: 2, sd@ffe05000: 0, mmc@ffe07000: 1
Loading Environment from nowhere... OK
In:    usbkbd,serial
Out:   vidconsole,serial
Err:   vidconsole,serial
gpio: pin periphs-banks73 (gpio 88) value is 0
gpio: pin periphs-banks73 (gpio 88) value is 1
Net:   eth0: ethernet@ff3f0000
Hit any key to stop autoboot:  0
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
U-Boot menu
1:	Debian GNU/Linux 13 (trixie) 7.1.3.1-mnt-reform-arm64
2:	Debian GNU/Linux 13 (trixie) 7.1.3.1-mnt-reform-arm64 (rescue target)
3:	Debian GNU/Linux 13 (trixie) 6.12.94-mnt-reform-arm64
4:	Debian GNU/Linux 13 (trixie) 6.12.94-mnt-reform-arm64 (rescue target)
Enter choice: 1:	Debian GNU/Linux 13 (trixie) 7.1.3.1-mnt-reform-arm64
Retrieving file: /vmlinuz-7.1.3.1-mnt-reform-arm64
Retrieving file: /initrd.img-7.1.3.1-mnt-reform-arm64
append: ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ro no_console_suspend console=ttyAML0,115200 pci=pcie_bus_perf libata.force=noncq nvme_core.default_ps_max_latency_us=0 console=tty1 fbcon=rotate:3 fbcon=font:TER16x32 console=tty1
Retrieving file: /dtb-7.1.3.1-mnt-reform-arm64
Moving Image from 0x8080000 to 0x8200000, end=a9f0000
## Flattened Device Tree blob at 08008000
   Booting using the fdt blob at 0x8008000
Working FDT set to 8008000
   Loading Ramdisk to 3cc17000, end 3ffff7e5 ... OK
   Loading Device Tree to 000000003cc06000, end 000000003cc16ae9 ... OK
Working FDT set to 3cc06000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 7.1.3.1-mnt-reform-arm64 (debian-kernel@lists.debian.org) (aarch64-linux-gnu-gcc-14 (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Debian 7.1.3-1~bpo13+1+reform20260812T225358Z (20
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: MNT Pocket Reform with BPI-CM4 Module
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000e5000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000e5000000..0x00000000f4ffffff (262144 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000005000000..0x00000000052fffff (3072 KiB) nomap non-reusable secmon@5000000
[    0.000000] OF: reserved mem: 0x0000000005300000..0x00000000072fffff (32768 KiB) nomap non-reusable secmon@5300000
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000f4ffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0xe480a640-0xe480de3f]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] RME: RMM doesn't support RSI version 1.0. Supported range: 1.0-0.0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000f4ffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000072fffff]
[    0.000000]   node   0: [mem 0x0000000007300000-0x00000000f4ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000f4ffffff]
[    0.000000] On node 0, zone DMA: 12288 pages in unavailable ranges
[    0.000000] percpu: Embedded 36 pages/cpu s108056 r8192 d31208 u147456
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ro no_console_suspend console=ttyAML0,115200 pci=pcie_bus_perf libata.force=noncq nvme_core.default_ps_max_latency_us=0 console=tty1 fbcon=rotate:3 fbcon=font:TER16x32 console=tty1
[    0.000000] PCIe ASPM is disabled
[    0.000000] printk: log buffer data + meta data: 131072 + 557056 = 688128 bytes
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 3MB
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000dfe00000-0x00000000e0200000] (4MB)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1003520
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] ftrace: allocating 55355 entries in 218 pages
[    0.000000] ftrace: allocated 218 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6.
[    0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000758] Console: colour dummy device 80x25
[    0.000777] printk: legacy console [tty1] enabled
[    0.002072] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002101] pid_max: default: 32768 minimum: 301
[    0.005141] landlock: Up and running.
[    0.005159] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.005456] AppArmor: AppArmor initialized
[    0.005538] TOMOYO Linux initialized
[    0.006105] LSM support for eBPF active
[    0.007730] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.007769] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.008733] VFS: Finished mounting rootfs on nullfs
[    0.015290] rcu: Hierarchical SRCU implementation.
[    0.015330] rcu: 	Max phase no-delay instances is 1000.
[    0.015642] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.020141] EFI services will not be available.
[    0.020848] smp: Bringing up secondary CPUs ...
[    0.021895] Detected VIPT I-cache on CPU1
[    0.022118] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.023875] CPU features: detected: Spectre-v2
[    0.023893] CPU features: detected: Spectre-v4
[    0.023898] CPU features: detected: Spectre-BHB
[    0.023904] CPU features: detected: ARM erratum 858921
[    0.023915] Detected VIPT I-cache on CPU2
[    0.024050] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.024069] arch_timer: CPU2: Trapping CNTVCT access
[    0.024082] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
[    0.025182] Detected VIPT I-cache on CPU3
[    0.025287] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.025297] arch_timer: CPU3: Trapping CNTVCT access
[    0.025305] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
[    0.026311] Detected VIPT I-cache on CPU4
[    0.026416] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.026426] arch_timer: CPU4: Trapping CNTVCT access
[    0.026434] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
[    0.027538] Detected VIPT I-cache on CPU5
[    0.027645] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.027655] arch_timer: CPU5: Trapping CNTVCT access
[    0.027663] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
[    0.027789] smp: Brought up 1 node, 6 CPUs
[    0.027982] SMP: Total of 6 processors activated.
[    0.027995] CPU: All CPU(s) started at EL2
[    0.028034] CPU features: detected: 32-bit EL0 Support
[    0.028049] CPU features: detected: 32-bit EL1 Support
[    0.028065] CPU features: detected: CRC32 instructions
[    0.028088] CPU features: detected: PMUv3
[    0.028194] alternatives: applying system-wide alternatives
[    0.053706] node 0 deferred pages initialised in 24ms
[    0.053786] Memory: 3533556K/4014080K available (18624K kernel code, 5126K rwdata, 12080K rodata, 3904K init, 912K bss, 212892K reserved, 262144K cma-reserved)
[    0.055331] devtmpfs: initialized
[    0.066410] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066479] posixtimers hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.066563] futex hash table entries: 2048 (131072 bytes on 1 NUMA nodes, total 128 KiB, linear).
[    0.069787] 22544 pages in range for non-PLT usage
[    0.069802] 514064 pages in range for PLT usage
[    0.074483] DMI: not present or invalid.
[    0.077369] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.078880] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.078929] audit: initializing netlink subsys (disabled)
[    0.079160] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[    0.081875] thermal_sys: Registered thermal governor 'fair_share'
[    0.081884] thermal_sys: Registered thermal governor 'bang_bang'
[    0.081899] thermal_sys: Registered thermal governor 'step_wise'
[    0.081910] thermal_sys: Registered thermal governor 'user_space'
[    0.081920] thermal_sys: Registered thermal governor 'power_allocator'
[    0.081984] cpuidle: using governor ladder
[    0.082030] cpuidle: using governor menu
[    0.082341] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.082492] ASID allocator initialised with 65536 entries
[    0.084138] Serial: AMBA PL011 UART driver
[    0.090529] /soc/bus@ff600000/hdmi-tx@0: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.090970] /soc/vpu@ff900000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.091001] /soc/vpu@ff900000: Fixed dependency cycle(s) with /soc/bus@ff600000/hdmi-tx@0
[    0.091029] /soc/interrupt-controller@ffc01000: Fixed dependency cycle(s) with /soc/interrupt-controller@ffc01000
[    0.091054] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000/panel@0
[    0.091090] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.091138] /soc/bus@ffd00000/dsi@7000/panel@0: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.092248] /soc/bus@ff600000/hdmi-tx@0: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.092817] /soc/bus@ff600000/hdmi-tx@0: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.105313] /soc/bus@ff600000/hdmi-tx@0: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.105404] /soc/vpu@ff900000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.105437] /soc/vpu@ff900000: Fixed dependency cycle(s) with /soc/bus@ff600000/hdmi-tx@0
[    0.105769] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000/panel@0
[    0.105808] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.105972] /soc/bus@ffd00000/dsi@7000/panel@0: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.107464] /soc/vpu@ff900000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.107524] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000/panel@0
[    0.107564] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/vpu@ff900000
[    0.107756] /soc/bus@ffd00000/dsi@7000/panel@0: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    0.114873] /soc/bus@ff600000/hdmi-tx@0: Fixed dependency cycle(s) with /hdmi-connector
[    0.114975] /hdmi-connector: Fixed dependency cycle(s) with /soc/bus@ff600000/hdmi-tx@0
[    0.125101] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.125127] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.125139] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.125149] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.125160] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.125169] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.125179] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.125188] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.134822] ACPI: Interpreter disabled.
[    0.137057] iommu: Default domain type: Translated
[    0.137080] iommu: DMA domain TLB invalidation policy: strict mode
[    0.141168] pps_core: LinuxPPS API ver. 1 registered
[    0.141186] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.141206] PTP clock support registered
[    0.141261] EDAC MC: Ver: 3.0.0
[    0.141642] scmi_core: SCMI protocol bus registered
[    0.143379] NetLabel: Initializing
[    0.143397] NetLabel:  domain hash size = 128
[    0.143407] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.143462] NetLabel:  unlabeled traffic allowed by default
[    0.143723] vgaarb: loaded
[    0.144133] clocksource: Switched to clocksource arch_sys_counter
[    0.146362] VFS: Disk quotas dquot_6.6.0
[    0.146491] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.147395] AppArmor: AppArmor Filesystem Enabled
[    0.147556] pnp: PnP ACPI: disabled
[    0.155190] NET: Registered PF_INET protocol family
[    0.155430] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.159789] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.159883] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.159967] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.160399] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.160751] TCP: Hash tables configured (established 32768 bind 32768)
[    0.161141] MPTCP token hash table entries: 4096 (order: 5, 98304 bytes, linear)
[    0.161345] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.161802] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.161837] NET: Registered PF_XDP protocol family
[    0.161862] PCI: CLS 0 bytes, default 64
[    0.162175] Trying to unpack rootfs image as initramfs...
[    0.171637] kvm [1]: nv: 570 coarse grained trap handlers
[    0.171851] kvm [1]: nv: 710 fine grained trap handlers
[    0.172229] kvm [1]: IPA Size Limit: 40 bits
[    0.173885] kvm [1]: vgic interrupt IRQ9
[    0.173937] kvm [1]: Hyp nVHE mode initialized successfully
[    0.179160] Initialise system trusted keyrings
[    0.179261] Key type blacklist registered
[    0.179468] workingset: timestamp_bits=42 (anon: 38) max_order=20 bucket_order=0 (anon: 0)
[    0.184988] fuse: init (API version 7.45)
[    0.185810] integrity: Platform Keyring initialized
[    0.185855] integrity: Machine keyring initialized
[    0.185946] Key type asymmetric registered
[    0.185958] Asymmetric key parser 'x509' registered
[    0.186150] alg: self-tests disabled
[    0.186453] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.186657] io scheduler mq-deadline registered
[    0.190203] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[    0.212444] ledtrig-cpu: registered to indicate activity on CPUs
[    0.230971] soc soc0: Amlogic Meson G12B (A311D) Revision 29:b (10:2) Detected
[    0.237257] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.240572] Serial: AMBA driver
[    0.241893] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart
[    0.241957] printk: legacy console [ttyAML0] enabled
[    0.992129] Freeing initrd memory: 53152K
[    0.999857] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 15, base_baud = 1500000) is a meson_uart
[    1.586451] serial serial0: tty port ttyAML6 registered
[    1.592021] msm_serial: driver initialized
[    1.596236] SuperH (H)SCI(F) driver initialized
[    1.604749] mousedev: PS/2 mouse device common for all mice
[    1.611152] pwrseq_emmc emmc-pwrseq: EMMC reset pin tied to a sleepy GPIO driver; reset on emergency-reboot disabled
[    1.617203] meson-sm: secure-monitor enabled
[    1.626803] NET: Registered PF_INET6 protocol family
[    1.628192] Segment Routing with IPv6
[    1.629789] RPL Segment Routing with IPv6
[    1.633840] In-situ OAM (IOAM) with IPv6
[    1.637724] mip6: Mobile IPv6
[    1.640634] NET: Registered PF_PACKET protocol family
[    1.645747] mpls_gso: MPLS GSO support
[    1.658898] registered taskstats version 1
[    1.659131] Loading compiled-in X.509 certificates
[    1.692118] Loaded X.509 cert 'Build time autogenerated kernel key: bc13c344c3ed3ce377f479fcc383bb83682a8489'
[    1.706208] Demotion targets for Node 0: null
[    1.706896] Key type .fscrypt registered
[    1.708863] Key type fscrypt-provisioning registered
[    1.772293] Key type encrypted registered
[    1.772349] AppArmor: AppArmor sha256 policy hashing enabled
[    1.776344] ima: No TPM chip found, activating TPM-bypass!
[    1.781797] ima: Allocated hash algorithm: sha256
[    1.786712] ima: No architecture policies found
[    1.791060] evm: Initialising EVM extended attributes:
[    1.796135] evm: security.selinux
[    1.799377] evm: security.SMACK64 (disabled)
[    1.803648] evm: security.SMACK64EXEC (disabled)
[    1.808228] evm: security.SMACK64TRANSMUTE (disabled)
[    1.813250] evm: security.SMACK64MMAP (disabled)
[    1.817841] evm: security.apparmor
[    1.821221] evm: security.ima
[    1.824174] evm: security.capability
[    1.827717] evm: HMAC attrs: 0x1
[    1.854039] meson-pcie fc000000.pcie: host bridge /soc/pcie@fc000000 ranges:
[    1.855491] meson-pcie fc000000.pcie:       IO 0x00fc600000..0x00fc6fffff -> 0x0000000000
[    1.863634] meson-pcie fc000000.pcie:      MEM 0x00fc700000..0x00fdffffff -> 0x00fc700000
[    1.871915] meson-pcie fc000000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 4G
[    1.972149] meson-pcie fc000000.pcie: PCIe Gen.2 x1 link up
[    1.972538] meson-pcie fc000000.pcie: PCI host bridge to bus 0000:00
[    1.978440] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.983883] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff]
[    1.990121] pci_bus 0000:00: root bus resource [mem 0xfc700000-0xfdffffff]
[    1.996993] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400 PCIe Root Port
[    2.004260] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    2.010401] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.015608] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.021673] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.028431] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff pref]
[    2.035648] pci 0000:00:00.0: supports D1
[    2.039611] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.049525] pci 0000:01:00.0: [c0a9:5421] type 00 class 0x010802 PCIe Endpoint
[    2.053248] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[    2.060167] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[    2.074765] pci 0000:00:00.0: bridge window [mem 0xfc700000-0xfc7fffff]: assigned
[    2.081997] pci 0000:00:00.0: ROM [mem 0xfc800000-0xfc80ffff pref]: assigned
[    2.089020] pci 0000:01:00.0: BAR 0 [mem 0xfc700000-0xfc703fff 64bit]: assigned
[    2.096311] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.101489] pci 0000:00:00.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    2.108248] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.113884] pci_bus 0000:00: resource 5 [mem 0xfc700000-0xfdffffff]
[    2.120120] pci_bus 0000:01: resource 1 [mem 0xfc700000-0xfc7fffff]
[    2.126364] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  256
[    2.134800] pci 0000:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  256
[    2.143400] pcieport 0000:00:00.0: PME: Signaling with IRQ 21
[    2.149152] pcieport 0000:00:00.0: AER: enabled with IRQ 21
[    2.162131] clk: Disabling unused clocks
[    2.162348] PM: genpd: Disabling unused power domains
[    2.162915] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[    2.209707] Freeing unused kernel memory: 3904K
[    2.256948] Checked W+X mappings: passed, no W+X pages found
[    2.257017] Run /init as init process
[    2.273575] mmc1: new HS200 MMC card at address 0001
[    2.275610] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    2.279911]  mmcblk1: p1
[    2.280804] mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB
[    2.287561] mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB
[    2.292069] mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (237:0)
[    2.997303] cpufreq: cpufreq_policy_online: CPU2: Running at unlisted initial frequency: 999999 kHz, changing to: 1000000 kHz
[    3.019831] meson-gx-mmc ffe05000.mmc: Got CD GPIO
[    3.054315] meson-vrtc ff8000a8.rtc: registered as rtc1
[    3.110677] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
[    3.110718] dwc3-meson-g12a ffe09000.usb: USB3 ports: 0
[    3.125138] mc: Linux media interface: v0.10
[    3.136292] Key type psk registered
[    3.160813] spidev@0 enforce active low on GPIO handle
[    3.165567] debugfs: 'ff800280.cec' already exists in 'regmap'
[    3.172867] panfrost ffe40000.gpu: clock rate = 24000000
[    3.172948] panfrost ffe40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[    3.173108] /soc/bus@ffd00000/dsi@7000: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000/panel@0
[    3.184901] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
[    3.185032] Registered IR keymap rc-cec
[    3.185126] rc rc0: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0
[    3.185232] input: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0/input0
[    3.203046] /soc/bus@ffd00000/dsi@7000/panel@0: Fixed dependency cycle(s) with /soc/bus@ffd00000/dsi@7000
[    3.210157] meson8b-dwmac ff3f0000.ethernet: IRQ sfty not found
[    3.234714] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
[    3.240906] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    3.247656] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
[    3.249591] videodev: Linux video capture interface: v2.00
[    3.253079] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
[    3.265750] meson8b-dwmac ff3f0000.ethernet: Active PHY interface: GMII/MII (0)
[    3.272784] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    3.273095] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
[    3.278561] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
[    3.279614] rtc-pcf8523 1-0068: registered as rtc0
[    3.282038] rtc-pcf8523 1-0068: setting system clock to 2026-08-13T20:35:20 UTC (1786653320)
[    3.286011] meson8b-dwmac ff3f0000.ethernet: COE Type 2
[    3.300345] panfrost ffe40000.gpu: features: 00000000,00000df7, issues: 00000000,00000400
[    3.307138] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
[    3.312325] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    3.320269] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
[    3.332302] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[    3.334714] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
[    3.340649] meson-drm ff900000.vpu: CVBS Output connector not available
[    3.352407] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
[    3.352419] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.367250] nvme nvme0: pci function 0000:01:00.0
[    3.371786] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
[    3.378924] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    3.379792] mdio_bus mdio_mux-0.0: MDIO device at address 0 is missing.
[    3.392833] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    3.398779] panfrost ffe40000.gpu: [drm] Using Transparent Hugepage
[    3.404481] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    3.413935] usbcore: registered new interface driver usbfs
[    3.418472] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    3.425859] usbcore: registered new interface driver hub
[    3.445620] usbcore: registered new device driver usb
[    3.456162] [drm] Initialized panfrost 1.6.0 for ffe40000.gpu on minor 0
[    3.474676] nvme nvme0: missing or invalid SUBNQN field.
[    3.626667] hwmon hwmon2: temp1_input not attached to any thermal zone
[    3.627617] hwmon hwmon2: temp2_input not attached to any thermal zone
[    3.634172] hwmon hwmon2: temp3_input not attached to any thermal zone
[    3.640661] hwmon hwmon2: temp9_input not attached to any thermal zone
[    3.647079] nvme nvme0: passthrough uses implicit buffer lengths
[    3.675455] nvme nvme0: allocated 32 MiB host memory buffer (8 segments).
[    3.713088] nvme nvme0: 6/0/0 default/read/poll queues
[    3.743885] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.754569] meson-gx-mmc ffe03000.mmc: allocated mmc-pwrseq
[    3.757167] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    3.757364] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
[    3.760446] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    3.767334] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
[    3.774159] meson-drm ff900000.vpu: CVBS Output connector not available
[    3.781629] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[    3.812937] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    3.817516] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    3.825854] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    3.843686] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    3.844101] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    3.850603] meson-drm ff900000.vpu: CVBS Output connector not available
[    3.880932] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    3.885461] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    3.893705] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    3.911365] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    3.911907] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    3.918303] meson-drm ff900000.vpu: CVBS Output connector not available
[    3.948280] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    3.952803] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    3.961112] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    3.978048] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    3.978563] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    3.984982] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.016299] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.023720] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.029281] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.041269] meson-gx-mmc ffe03000.mmc: card claims to support voltages below defined range
[    4.044427] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.051523] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.057982] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.077909] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.077965] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    4.085539] xhci-hcd xhci-hcd.1.auto: hcc params 0x0228fe64 hci version 0x110 quirks 0x0000808000000010
[    4.089260] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.094789] xhci-hcd xhci-hcd.1.auto: irq 44, io mem 0xff500000
[    4.104906] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.110550] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.118927] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.123719] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    4.140277] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    4.140526] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.140527] mmc2: new UHS-I speed SDR104 SDIO card at address 0001
[    4.140841] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.140873] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.146894] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    4.165311] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.165388] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.172270] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.180208] usb usb1: Product: xHCI Host Controller
[    4.180211] usb usb1: Manufacturer: Linux 7.1.3.1-mnt-reform-arm64 xhci-hcd
[    4.180213] usb usb1: SerialNumber: xhci-hcd.1.auto
[    4.180876] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.190454] hub 1-0:1.0: USB hub found
[    4.234334] hub 1-0:1.0: 2 ports detected
[    4.239557] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.240106] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.246451] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[    4.252341] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.260120] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.267075] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.274279] usb usb2: Product: xHCI Host Controller
[    4.285687] usb usb2: Manufacturer: Linux 7.1.3.1-mnt-reform-arm64 xhci-hcd
[    4.292617] usb usb2: SerialNumber: xhci-hcd.1.auto
[    4.297875] hub 2-0:1.0: USB hub found
[    4.301225] hub 2-0:1.0: 1 port detected
[    4.304178] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.315193] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.323399] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.340241] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.340618] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.347188] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.376961] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.381405] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.389661] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.409139] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.409455] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.416069] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.444300] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.448725] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.457035] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.476593] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.479783] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.483534] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.500186] usb 1-2: new high-speed USB device number 2 using xhci-hcd
[    4.516891] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.521332] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.529722] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.547479] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.547892] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.554427] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.588181] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.592723] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.601111] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.618036] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.618517] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.624981] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.644344] usb 1-2: New USB device found, idVendor=0424, idProduct=2412, bcdDevice= b.b2
[    4.646890] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.652190] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.664174] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.672502] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.687472] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.687942] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.691086] hub 1-2:1.0: USB hub found
[    4.694421] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.698222] hub 1-2:1.0: 2 ports detected
[    4.727051] usbcore: registered new device driver onboard-usb-dev
[    4.728275] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.737666] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.746016] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.762921] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.763343] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.769902] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.804183] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.808658] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.817070] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.834485] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.834889] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.841428] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.872194] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.876736] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.885084] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.903130] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.903646] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.910079] meson-drm ff900000.vpu: CVBS Output connector not available
[    4.940200] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.944785] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.953175] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.970077] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    4.970567] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    4.977042] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.004186] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.008777] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.017153] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.033967] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.034463] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.040912] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.044157] usb 1-2.1: new high-speed USB device number 3 using xhci-hcd
[    5.068198] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.072801] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.081181] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.097985] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.098526] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.104929] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.132209] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.136801] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.145174] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.156682] usb 1-2.1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    5.161487] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    5.162292] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.168745] usb 1-2.1: SerialNumber: 0C010851A4CD
[    5.179509] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.185995] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.203007] hub 1-2.1:1.0: USB hub found
[    5.203270] hub 1-2.1:1.0: 4 ports detected
[    5.216937] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.221364] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.229831] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.248302] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.248701] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.255249] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.284832] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.289347] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.297653] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.316075] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.316523] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.323106] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.352343] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.356899] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.365231] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.382837] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.383285] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.388153] usb 1-2.2: new full-speed USB device number 4 using xhci-hcd
[    5.389788] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.428341] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.432790] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.441274] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.458669] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.459086] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.465618] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.489908] usb 1-2.2: New USB device found, idVendor=1209, idProduct=6d07, bcdDevice= 0.01
[    5.492646] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.499918] usb 1-2.2: Product: Pocket Reform System Controller 2.0
[    5.500193] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.506153] usb 1-2.2: Manufacturer: MNT
[    5.506159] usb 1-2.2: SerialNumber: DE635441932A1F34
[    5.506450] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.533630] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.560008] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.560606] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.567006] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.592166] usb 1-2.1.3: new full-speed USB device number 5 using xhci-hcd
[    5.596186] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.603560] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.612018] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.624874] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.625871] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.632480] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.660193] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.664673] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.673058] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.689662] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.690083] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.696606] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.724193] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.728666] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.737073] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.753756] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.754174] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.760699] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.792192] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.796666] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.800525] usb 1-2.1.3: New USB device found, idVendor=1209, idProduct=6d06, bcdDevice= 0.01
[    5.805074] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.812705] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.829077] usb 1-2.1.3: Product: Pocket Reform Input 2.0
[    5.834462] usb 1-2.1.3: Manufacturer: MNT
[    5.834960] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.838515] usb 1-2.1.3: SerialNumber: DE62549203897A2C
[    5.849610] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.856260] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.884346] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.890476] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.897514] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.913903] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.914322] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.920846] meson-drm ff900000.vpu: CVBS Output connector not available
[    5.948291] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.952896] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.954547] hid: raw HID events driver (C) Jiri Kosina
[    5.960930] usb 1-2.1.4: new high-speed USB device number 6 using xhci-hcd
[    5.962734] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    5.965784] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    5.988251] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    5.993696] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.024292] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.028687] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.031159] usbcore: registered new interface driver usbhid
[    6.037003] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.041858] usbhid: USB HID core driver
[    6.062812] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.064238] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.069786] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.080697] input: MNT Pocket Reform Input 2.0 Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.1.auto/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.0/0003:1209:6D06.0001/input/input1
[    6.104178] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.108628] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.116972] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.132374] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.133661] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.139304] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.168335] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.172789] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.181215] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.195613] usb 1-2.1.4: New USB device found, idVendor=2c7c, idProduct=0801, bcdDevice= 5.04
[    6.197118] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.198551] usb 1-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.207678] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.211523] usb 1-2.1.4: Product: RM520N-GL
[    6.211528] usb 1-2.1.4: Manufacturer: Quectel
[    6.211563] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.218458] usb 1-2.1.4: SerialNumber: d999e14b
[    6.244306] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.249273] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.257237] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.274047] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.274459] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.280986] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.292343] input: MNT Pocket Reform Input 2.0 Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.1.auto/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.0/0003:1209:6D06.0001/input/input2
[    6.304473] input: MNT Pocket Reform Input 2.0 as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.1.auto/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.0/0003:1209:6D06.0001/input/input3
[    6.320465] hid-generic 0003:1209:6D06.0001: input,hidraw0: USB HID v1.11 Keyboard [MNT Pocket Reform Input 2.0] on usb-xhci-hcd.1.auto-2.1.3/input0
[    6.321065] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.343819] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.351996] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.370077] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.370405] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.377000] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.408207] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.412712] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.417494] meson8b-dwmac ff3f0000.ethernet end0: renamed from eth0
[    6.421332] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.445753] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.446066] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.452730] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.480995] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.485558] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.493962] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.512842] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.513223] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.519768] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.552217] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.556829] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.565097] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.583004] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.583436] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.590004] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.620271] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.626810] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.633345] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.655381] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.655849] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.662377] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.696228] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.700830] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.709190] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.728071] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.728557] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.735058] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.765030] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.769682] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.777875] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.797402] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.797929] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.804365] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.832855] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.837583] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.845856] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.863597] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.864363] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.864870] SPI driver mnt_sc has no spi_device_id for mntre,system-controller
[    6.870555] meson-drm ff900000.vpu: CVBS Output connector not available
[    6.877750] mnt_sc spi0.0: MNT System Controller v4
[    6.909119] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    6.913841] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    6.922075] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    6.942402] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_probe] start...
[    6.944060] mnt_sc spi0.0: [mntsc_gpio_set] (set-gpio 0 1)
[    6.953104] mnt_sc spi0.0: [mntsc_gpio_set] (set-gpio 8 0)
[    6.958522] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_probe] jdi_panel_add done.
[    6.963133] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_probe] done.
[    6.970893] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[    6.976111] meson-drm ff900000.vpu: viu-hold-fifo-lines from device tree: 0
[    6.982592] meson-drm ff900000.vpu: CVBS Output connector not available
[    7.016308] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    7.020954] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    7.029349] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    7.037191] reform2_lpc: loading out-of-tree module taints kernel.
[    7.037908] [drm] Initialized meson 1.0.0 for ff900000.vpu on minor 1
[    7.043404] reform2_lpc: module verification failed: signature and/or required key missing - tainting kernel
[    7.061214] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_get_modes] panel_version: 0
[    7.067909] panel-mnt-pocket-reform ffd07000.dsi.0: vsync-shift from device tree: 1
[    7.067952] meson-drm ff900000.vpu: [drm] kms: can't enable cloning when we probably wanted to.
[    7.068184] random: crng init done
[    7.143637] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    7.143729] device-mapper: uevent: version 1.0.3
[    7.144083] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    7.160184] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_prepare] prepared: 0
[    7.160200] panel-mnt-pocket-reform ffd07000.dsi.0: [display] init in prepare...
[    7.160202] panel-mnt-pocket-reform ffd07000.dsi.0: [mnt_panel_power_on] panel version: 0
[    7.264167] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_init] enabled: 0 prepared: 0
[    7.285147] meson-dw-mipi-dsi ffd07000.dsi: Timeout during read operation
[    7.285154] panel-mnt-pocket-reform ffd07000.dsi.0: [mnt_panel_detect_version] read register 12a: 0x0
[    7.285159] panel-mnt-pocket-reform ffd07000.dsi.0: [mnt_panel_detect_version] panel not ready (-110).
[    7.285165] panel-mnt-pocket-reform ffd07000.dsi.0: [mnt_panel_detect_version] detected panel_version: 2
[    7.285170] panel-mnt-pocket-reform ffd07000.dsi.0: [mnt_panel_power_on] panel version: 2
[    7.285184] mnt_sc spi0.0: [mntsc_gpio_set] (set-gpio 0 0)
[    7.392145] mnt_sc spi0.0: [mntsc_gpio_set] (set-gpio 0 1)
[    7.516135] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.537145] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.558150] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.579159] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.600137] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.621140] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.642151] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.663153] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.684133] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.705143] meson-dw-mipi-dsi ffd07000.dsi: failed to write command FIFO
[    7.726149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.747159] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.768136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.789139] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.809159] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.830147] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.851157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.872136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.893142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.914151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.935153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.956132] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.977143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    7.998146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.019156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.039193] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.060149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.081163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.102175] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.123186] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.144148] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.165162] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.186173] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.207186] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.228147] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.249163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.270175] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.291188] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.312148] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.333163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.354176] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.375188] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.396149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.417164] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.438178] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.459189] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.480149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.501163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.522176] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.543188] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.564150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.585148] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.606147] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.627158] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.648136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.669140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.690151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.711156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.732135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.753144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.774146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.795157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.816136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.837140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.858150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.879155] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.900135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.921144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.942145] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.963156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    8.984137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.005140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.026151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.047156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.068135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.089146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.110146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.131158] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.152145] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.173143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.194150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.215156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.236135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.257143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.278146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.299157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.320137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.341140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.362151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.383157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.404135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.425146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.446024] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.466152] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.487154] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.507164] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.528137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.549142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.570150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.591160] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.612135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.632144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.653144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.674154] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.695157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.716136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.737142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.757150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.778146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.799157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.820136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.841145] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.862151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.883156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.904135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.925149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.946146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.967154] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[    9.988137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.009147] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.030151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.050170] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.071157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.092142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.113139] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.134150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.155152] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.176143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.197143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.218148] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.239156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.260141] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.281139] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.302149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.323152] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.344137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.365143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.386149] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.407157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.428136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.449139] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.470150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.491153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.511163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.532136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.553142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.574150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.595153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.616132] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.637144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.658156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.679160] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.699187] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.720135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.741144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.762146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.783157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.804137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.825140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.846151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.867156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.888135] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.909143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.930146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.951156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.972136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   10.993140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.014151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.035154] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.056134] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.077142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.098145] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.119157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.140137] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.162375] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.183161] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.204134] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.225147] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.246151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.267157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.288136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.309140] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.329155] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.350146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.371157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.392144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.413143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.434150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.455153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.476133] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.497144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.518146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.539157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.560136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.581142] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.602150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.623153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.644132] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.665144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.686146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   11.707157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.727287] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.748009] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.768132] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.789144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.810156] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.831158] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.852136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.873143] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.894151] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.915153] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.936132] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.957144] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.978146] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   11.999157] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.020136] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.040155] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.061165] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.082176] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.103192] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.124150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.145163] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.166177] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.187192] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.208150] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.229165] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.250177] meson-dw-mipi-dsi ffd07000.dsi: failed to get available write payload FIFO
[   12.250188] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] sent tables OK
[   12.271192] meson-dw-mipi-dsi ffd07000.dsi: failed to get available command FIFO
[   12.271202] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] failed to set exit sleep mode: -110
[   12.380717] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] OK
[   12.380725] mnt_sc spi0.0: [mntsc_gpio_set] (set-gpio 8 1)
[   12.384914] mnt_sc spi0.0: enabling PWM display backlight control by MNT System Controller.
[   12.385190] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_enable] enabled: 0 prepared: 1
[   12.404911] Console: switching to colour frame buffer device 120x37
[   14.269040] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
[   14.280591] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[   14.280604] panel-mnt-pocket-reform ffd07000.dsi.0: vsync-shift from device tree: 1
[   14.280633] meson-drm ff900000.vpu: [drm] kms: can't enable cloning when we probably wanted to.
[   14.297548] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[   14.309561] panel-mnt-pocket-reform ffd07000.dsi.0: vsync-shift from device tree: 1
[   14.309592] meson-drm ff900000.vpu: [drm] kms: can't enable cloning when we probably wanted to.
display is blank, backlight on, no contents
from encryption password to login, sending reform check next
[  160.832147] raid6: neonx8   gen()  4822 MB/s
[  160.900124] raid6: neonx4   gen()  6397 MB/s
[  160.968129] raid6: neonx2   gen()  5011 MB/s
[  161.036127] raid6: neonx1   gen()  3659 MB/s
[  161.104128] raid6: int64x8  gen()  2823 MB/s
[  161.172131] raid6: int64x4  gen()  3130 MB/s
[  161.240128] raid6: int64x2  gen()  2992 MB/s
[  161.308199] raid6: int64x1  gen()  2458 MB/s
[  161.309760] raid6: using algorithm neonx4 gen() 6397 MB/s
[  161.380127] raid6: .... xor() 4778 MB/s, rmw enabled
[  161.381456] raid6: using neon recovery algorithm
[  161.402963] xor: measuring software checksum speed
[  161.404687]    neon            :  8244 MB/sec
[  161.408112]    32regs          :  8863 MB/sec
[  161.412451]    8regs           :  8804 MB/sec
[  161.412454] xor: using function: 32regs (8863 MB/sec)
[  161.536021] Btrfs loaded, zoned=yes, fsverity=yes
[  162.962406] EXT4-fs (dm-2): orphan cleanup on readonly fs
[  162.965689] EXT4-fs (dm-2): mounted filesystem e08dd2d4-cd41-4979-a6ba-362b1418b90f ro with ordered data mode. Quota mode: none.
[  163.225461] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[  163.442160] systemd[1]: Inserted module 'autofs4'
[  163.538590] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[  163.538619] systemd[1]: Detected architecture arm64.
[  163.596187] systemd[1]: Hostname set to <The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of>.
[  163.793698] systemd[1]: bpf-restrict-fs: Failed to load BPF object: No such process
[  164.516746] systemd[1]: Queued start job for default target graphical.target.
[  164.561510] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[  164.567993] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[  164.582098] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[  164.597249] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[  164.612034] systemd[1]: Created slice user.slice - User and Session Slice.
[  164.624206] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[  164.639325] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[  164.660651] systemd[1]: Expecting device dev-disk-by\x2duuid-4665549e\x2d3b8d\x2d436d\x2d90b2\x2d98ac34a013f4.device - /dev/disk/by-uuid/4665549e-3b8d-436d-90b2-98ac34a013f4...
[  164.680843] systemd[1]: Expecting device dev-mmcblk1p1.device - /dev/mmcblk1p1...
[  164.689386] systemd[1]: Expecting device dev-ttyAML0.device - /dev/ttyAML0...
[  164.696678] systemd[1]: Reached target slices.target - Slice Units.
[  164.705466] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[  164.715653] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[  164.728981] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[  164.735702] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[  164.745644] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[  164.755771] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[  164.763246] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[  164.763289] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[  164.763559] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[  164.798487] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[  164.810250] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[  164.819857] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[  164.826872] systemd[1]: run-lock.mount: Directory /run/lock to mount over is not empty, mounting anyway.
[  164.833518] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[  164.882145] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[  164.889660] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[  164.899494] systemd[1]: Starting blk-availability.service - Availability of block devices...
[  164.916655] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[  164.930164] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[  164.965337] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[  164.989646] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[  165.002129] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[  165.015181] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[  165.029299] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[  165.042284] systemd[1]: Starting modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics...
[  165.048780] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
[  165.048906] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[  165.104700] systemd[1]: Starting systemd-journald.service - Journal Service...
[  165.116500] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[  165.121339] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[  165.138512] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[  165.150543] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[  165.154395] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[  165.178744] i2c_dev: i2c /dev entries driver
[  165.182044] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[  165.185112] systemd-journald[758]: Collecting audit messages is disabled.
[  165.191104] EXT4-fs (dm-2): re-mounted e08dd2d4-cd41-4979-a6ba-362b1418b90f r/w.
[  165.217873] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[  165.224904] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[  165.232002] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[  165.239584] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[  165.246947] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[  165.255255] systemd[1]: Finished blk-availability.service - Availability of block devices.
[  165.263728] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[  165.271844] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[  165.280563] systemd[1]: Finished lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[  165.293453] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[  165.293964] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[  165.308831] systemd[1]: modprobe@drm.service: Deactivated successfully.
[  165.309327] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[  165.322510] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[  165.323036] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[  165.338188] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[  165.338687] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[  165.352634] systemd[1]: modprobe@nvme_fabrics.service: Deactivated successfully.
[  165.353154] systemd[1]: Finished modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics.
[  165.368901] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[  165.376638] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[  165.388462] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[  165.396767] systemd[1]: Started systemd-journald.service - Journal Service.
[  165.486673] systemd-journald[758]: Received client request to flush runtime journal.
[  165.496338] systemd-journald[758]: File /var/log/journal/361c6eb20a9c49e08092b2fffe1c2f11/system.journal corrupted or uncleanly shut down, renaming and replacing.
[  166.041992] Adding 4194300k swap on /dev/mapper/reformvg-swap.  Priority:-1 extents:1 across:4194300k SS
[  166.452477] EXT4-fs (mmcblk1p1): mounted filesystem 9765ef0b-5ec6-5764-9b72-f2de518e0628 r/w with ordered data mode. Quota mode: none.
[  166.711191] audit: type=1400 audit(1786653483.924:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="adbd" pid=959 comm="apparmor_parser"
[  166.723927] hdmi-audio-codec hdmi-audio-codec.3.auto: HDMI: Unknown ELD version 0
[  166.725015] audit: type=1400 audit(1786653483.932:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="android_app" pid=960 comm="apparmor_parser"
[  166.747323] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  166.749850] audit: type=1400 audit(1786653483.932:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=957 comm="apparmor_parser"
[  166.760753] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[  166.775165] audit: type=1400 audit(1786653483.936:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=954 comm="apparmor_parser"
[  166.800870] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[  166.801494] audit: type=1400 audit(1786653483.936:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=955 comm="apparmor_parser"
[  166.815481] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  166.829923] audit: type=1400 audit(1786653483.936:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=956 comm="apparmor_parser"
[  166.838258] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  166.853995] audit: type=1400 audit(1786653483.956:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Xorg" pid=958 comm="apparmor_parser"
[  166.854006] audit: type=1400 audit(1786653483.960:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=962 comm="apparmor_parser"
[  166.854010] audit: type=1400 audit(1786653483.972:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=961 comm="apparmor_parser"
[  166.854013] audit: type=1400 audit(1786653483.976:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=969 comm="apparmor_parser"
[  166.870033] cdc_acm 1-2.2:1.0: ttyACM0: USB ACM device
[  166.911923] mnt_sc spi0.0: mntsc: couldn't parse response: err maxp
[  166.919291] usbcore: registered new interface driver cdc_acm
[  166.941560] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  166.949863] axg-sound-card sound: workaround active: internal PCM chmap controls mapped to device 0
[  167.025982] mnt_sc spi0.0: mntsc: couldn't parse response: err undf
[  167.088863] Bluetooth: Core ver 2.22
[  167.088960] NET: Registered PF_BLUETOOTH protocol family
[  167.088963] Bluetooth: HCI device and connection manager initialized
[  167.088976] Bluetooth: HCI socket layer initialized
[  167.088983] Bluetooth: L2CAP socket layer initialized
[  167.088991] Bluetooth: SCO socket layer initialized
[  167.136805] rtw88_8822cs mmc2:0001:1: WOW Firmware version 9.9.4, H2C version 15
[  167.137142] rtw88_8822cs mmc2:0001:1: Firmware version 9.9.15, H2C version 15
[  167.246751] usbcore: registered new interface driver cdc_wdm
[  167.357347] Bluetooth: HCI UART driver ver 2.3
[  167.359822] Bluetooth: HCI UART protocol H4 registered
[  167.363819] Bluetooth: HCI UART protocol LL registered
[  167.363832] Bluetooth: HCI UART protocol ATH3K registered
[  167.363875] Bluetooth: HCI UART protocol Three-wire (H5) registered
[  167.377914] qmi_wwan 1-2.1.4:1.4: cdc-wdm0: USB WDM device
[  167.380987] Bluetooth: HCI UART protocol Intel registered
[  167.391838] Bluetooth: HCI UART protocol Broadcom registered
[  167.391867] Bluetooth: HCI UART protocol QCA registered
[  167.391870] Bluetooth: HCI UART protocol AG6XX registered
[  167.391891] Bluetooth: HCI UART protocol Marvell registered
[  167.395462] qmi_wwan 1-2.1.4:1.4 wwan0: register 'qmi_wwan' at usb-xhci-hcd.1.auto-2.1.4, WWAN/QMI device, fe:7b:c6:24:c2:10
[  167.395609] usbcore: registered new interface driver qmi_wwan
[  167.411275] usbcore: registered new interface driver usbserial_generic
[  167.436639] usbserial: USB Serial support registered for generic
[  167.890777] meson8b-dwmac ff3f0000.ethernet end0: stmmac_dvr_remove: removing driver
[  168.008582] qmi_wwan 1-2.1.4:1.4 wwu2u1u4i4: renamed from wwan0
[  168.032531] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000c lmp_ver=0a lmp_subver=8822
[  168.037509] Bluetooth: hci0: RTL: rom_version status=0 version=3
[  168.051225] Bluetooth: hci0: RTL: btrtl_initialize: key id 0
[  168.053769] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cs_fw.bin
[  168.065483] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cs_config.bin
[  168.093362] Bluetooth: hci0: RTL: cfg_sz 33, total sz 38425
[  168.144479] usbcore: registered new interface driver option
[  168.148404] usbserial: USB Serial support registered for GSM modem (1-port)
[  168.155649] option 1-2.1.4:1.0: GSM modem (1-port) converter detected
[  168.156063] usb 1-2.1.4: GSM modem (1-port) converter now attached to ttyUSB0
[  168.168591] option 1-2.1.4:1.1: GSM modem (1-port) converter detected
[  168.169158] usb 1-2.1.4: GSM modem (1-port) converter now attached to ttyUSB1
[  168.169361] option 1-2.1.4:1.2: GSM modem (1-port) converter detected
[  168.170218] usb 1-2.1.4: GSM modem (1-port) converter now attached to ttyUSB2
[  168.195776] option 1-2.1.4:1.3: GSM modem (1-port) converter detected
[  168.196094] usb 1-2.1.4: GSM modem (1-port) converter now attached to ttyUSB3
[  168.315316] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  168.318657] Bluetooth: BNEP filters: protocol multicast
[  168.324038] Bluetooth: BNEP socket layer initialized
[  168.494959] NET: Registered PF_QIPCRTR protocol family
[  168.676047] Bluetooth: hci0: RTL: fw version 0xb5d66dcb
[  168.770821] Bluetooth: MGMT ver 1.23
[  168.799529] NET: Registered PF_ALG protocol family
[  168.858817] Bluetooth: RFCOMM TTY layer initialized
[  168.860696] Bluetooth: RFCOMM socket layer initialized
[  168.865083] Bluetooth: RFCOMM ver 1.11
[  172.387545] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
[  172.390570] meson8b-dwmac ff3f0000.ethernet: IRQ sfty not found
[  172.396633] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
[  172.403773] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[  172.403789] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
[  172.403792] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
[  172.403796] meson8b-dwmac ff3f0000.ethernet: Active PHY interface: GMII/MII (0)
[  172.403799] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
[  172.403801] meson8b-dwmac ff3f0000.ethernet: COE Type 2
[  172.403806] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
[  172.403809] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
[  172.403816] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
[  172.403820] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
[  172.403824] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  174.652122] netfs: FS-Cache loaded
[  174.662731] Key type dns_resolver registered
[  174.737983] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[  174.813946] Key type cifs.spnego registered
[  174.816450] Key type cifs.idmap registered
[  174.820704] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
[  174.822104] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[  174.825942] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[  174.826156] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[  174.826160] CIFS: Attempting to mount //10.0.0.13/Volume_Main
[  174.826259] CIFS: VFS: Error connecting to socket. Aborting operation.
[  174.826263] CIFS: VFS: cifs_mount failed w/return code = -101
[  174.828468] CIFS: Attempting to mount //10.0.0.13/Volume_Sec
[  174.901439] CIFS: VFS: Error connecting to socket. Aborting operation.
[  174.901451] CIFS: VFS: cifs_mount failed w/return code = -101
[  174.901491] CIFS: Attempting to mount //10.0.0.13/Home
[  174.918758] CIFS: VFS: Error connecting to socket. Aborting operation.
[  174.918774] CIFS: VFS: cifs_mount failed w/return code = -101
[  175.105975] kauditd_printk_skb: 127 callbacks suppressed
[  175.105985] audit: type=1400 audit(1786653492.320:139): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-copy" pid=1420 comm="apparmor_parser"
[  175.130348] audit: type=1400 audit(1786653492.344:140): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-start" pid=1424 comm="apparmor_parser"
[  175.164953] audit: type=1400 audit(1786653492.380:141): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default" pid=1428 comm="apparmor_parser"
[  175.164971] audit: type=1400 audit(1786653492.380:142): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-cgns" pid=1428 comm="apparmor_parser"
[  175.164975] audit: type=1400 audit(1786653492.380:143): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-mounting" pid=1428 comm="apparmor_parser"
[  175.164979] audit: type=1400 audit(1786653492.380:144): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-nesting" pid=1428 comm="apparmor_parser"
[  175.164985] audit: type=1400 audit(1786653492.380:145): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-waydroid" pid=1428 comm="apparmor_parser"
[  175.436125] meson8b-dwmac ff3f0000.ethernet end0: renamed from eth0
[  175.540182] rtw88_8822cs mmc2:0001:1: firmware failed to report density after scan
[  175.630564] meson8b-dwmac ff3f0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  175.660298] meson8b-dwmac ff3f0000.ethernet end0: PHY [mdio_mux-0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=51)
[  175.680144] meson8b-dwmac ff3f0000.ethernet end0: No Safety Features support found
[  175.687103] meson8b-dwmac ff3f0000.ethernet end0: PTP not supported by HW
[  175.693310] meson8b-dwmac ff3f0000.ethernet end0: configuring for phy/rgmii-txid link mode
[  175.821149] mmc2: card 0001 removed
[  175.845447] meson-gx-mmc ffe03000.mmc: allocated mmc-pwrseq
[  175.862825] audit: type=1400 audit(1786653493.076:146): apparmor="DENIED" operation="open" class="file" profile="/usr/sbin/cupsd" name="/etc/paperspecs" pid=1484 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[  175.938204] audit: type=1400 audit(1786653493.152:147): apparmor="DENIED" operation="capable" class="cap" profile="/usr/sbin/cupsd" pid=1484 comm="cupsd" capability=12  capname="net_admin"
[  176.128293] meson-gx-mmc ffe03000.mmc: card claims to support voltages below defined range
[  176.172365] mmc2: new UHS-I speed SDR104 SDIO card at address 0001
[  176.177971] rtw88_8822cs mmc2:0001:1: Firmware version 9.9.15, H2C version 15
[  176.184508] rtw88_8822cs mmc2:0001:1: WOW Firmware version 9.9.4, H2C version 15
[  184.337476]  fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1, possibly missing ALSA mixer-based routing or UCM profile
[  184.778633] panel-mnt-pocket-reform ffd07000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[  184.781329] panel-mnt-pocket-reform ffd07000.dsi.0: vsync-shift from device tree: 1
Debian GNU/Linux 13 The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of ttyAML0
The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of login:
nebula@The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of:~$ sudo reform-check
[sudo] password for nebula:
I: reform.debian.net is configured as a mirror in /etc/apt/sources.list.d
I: Assuming reform.debian.net stable mirror for this script
I: If this is incorrect, you can set the mirror to its default by re-running this script with --mirror=mntre.com
I: Contents of /proc/device-tree/model: MNT Pocket Reform with BPI-CM4 Module
I: `uname -a` output: Linux The-Reform-False-God-Of-The-Abyss-Entropys-Paradox-Conqueror-Of 7.1.3.1-mnt-reform-arm64 #1 SMP PREEMPT Debian 7.1.3-1~bpo13+1+reform20260812T225358Z (20 aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 7.1.3-1~bpo13+1+reform20260812T225358Z
I: Version of reform-tools: 1.88-1~bpo13+1+reform20251209T125945Z~bpo13+1
I: Version of system image: System Image v5: 2025-08-27
[  272.220761] SCSI subsystem initialized
I: Version of system controller firmware: 20260808
I: Version of keyboard firmware: 20260808
I: Version of Pocket Reform panel: 2
W: /sys/bus/spi/drivers/reform2_lpc/spi1.0/firmware does not exist -- is the reform2_lpc module loaded?
E: expected u-boot version string to start with upstream version but got: 2024.04-dirty
I: Contents of /proc/device-tree/chosen/u-boot,version: 2024.04-dirty
W: Unable to parse contents of /proc/device-tree/chosen/u-boot,version -- U-Boot too old?
I: Mount source of /boot: /dev/mmcblk1p1 (eMMC)
I: MNT Reform Desktop meta-package is not installed: reform-desktop-full
I: Depends of reform-desktop-full is not installed: alsa-ucm-conf
I: Depends of reform-desktop-full is not installed: engrampa
I: Depends of reform-desktop-full is not installed: espeak-ng
I: Depends of reform-desktop-full is not installed: firefox-esr
I: Depends of reform-desktop-full is not installed: gnome
I: Depends of reform-desktop-full is not installed: gnome-shell-extension-dashtodock
I: Depends of reform-desktop-full is not installed: hyfetch
I: Depends of reform-desktop-full is not installed: mesa-vulkan-drivers
I: Depends of reform-desktop-full is not installed: mpv
I: Depends of reform-desktop-full is not installed: nfs-common
I: Depends of reform-desktop-full is not installed: ptyxis
I: Depends of reform-desktop-full is not installed: rtkit
I: Depends of reform-desktop-full is not installed: sway
I: Depends of reform-desktop-full is not installed: thunar
I: Depends of reform-desktop-full is not installed: vulkan-tools
I: Recommends of reform-desktop-minimal is not installed: ezurio-qcacld-2.0-dkms
 + fbcon=rotate:3
 + fbcon=font:TER16x32
E: ACL of /dev/dri/renderD128 does not contain an entry for nebula -- missing access means no hardware rendering for non-root users
I: Install the package shellcheck for checking /boot/boot.scr for problems
W: eMMC does not contain latest bootloader
reform-flash-bootloader emmc
I: note that updating the bootloader on eMMC on your platform is not without risk!
display is off, no backlight, no contents. moving mouse wakes backlight, no contents
Oh whoops, that’s not good.
I cannot reproduce your setup right now. My A311D is in my classic Reform (the machine i’m typing this on right now) and my Pocket Reform has an RK3588 in it. Both work well with Debian with kernel from trixie-backports.
Did you consider the option of downgrading your system controller firmware and then not using the kernel from trixie-backports?
i mean i can temporarily do that, but that doesn’t fix the other screen issue i was trying to fix with @stephano (reason i pinged you is i’m hoping to nerdsnipe you and maybe you have a magic solution to this) here which the new mnt_sc module was meant to fix.
if that’s the final result, i’ll go off on my own and try fixing it myself from here but i’ll wait for you to let me know if i should do that. failing that i’ll downgrade. but i’m also concerned that the ACL thing will still be an issue, so before you go can you let me know how to fix that? even if it’s complicated or tedious
hardware accelerated rendering not working would just make your rendering slower. It does not disable your display.
I can only continue working on this tomorrow. If you figure this out before I do, please go ahead. I first want to see if I somehow get this reproduced myself.
