How did you do the flashing? You probably executed this and made sure to replace /dev/mmcblkX with the device of your sd-card?
No, I downloaded the image, as suggested:
I used something like gnome disks to flash the image to a card. I do have two partitons on the card, boot and root, that’s why I thought it would work. I had never used bmaptool before, and did not know I needed to. Also, I searched the documentation quickly after I read your post, and I don’t see any mention of it.
I’m not sure where I would have gotten the fingerprint from either.
If you never updated u-boot, then the “any“ image might not work because there is a very old u-boot version for i.MX8M+ which didn’t fill the `${bootargs}` with the right values.
If an “apt update; apt full-upgrade” does not upgrade u-boot, I have not. That would be a thing that I did not know that I had to do outside of regular updates.
I was confused as well. It appears that it is coming from the emmc/nvme that is already existing. I get the usual prompt to decrypt my nvme, for which I put in my password. The boot looks normal, until it drops to rescue mode, where I can enter my root password, which brings me to a prompt in the updated system with the 6.15 kernel, or I can hit ctrl-d which finishes the boot normally.
I apologize for my lack of knowledge, but I’m done plenty with x86, and that’s why I asked how to set it. From my perspective, it just looks like it’s booting from the nvme, but then fails, asking for rescue mode, which for some reason, I can just bypass and boot normally.
There are indeed two partitions on my sd card, but I suspect that the names are wrong, as I did not do it as you mentioned. I thought that since the image is for THE pocket reform, that the names would have already been set.
Since this is getting pretty crunchy, I’m going to back up all of my data from the machine now, in anticipation of maybe having to wipe my nvme. (Does “booting” the sd mean wiping my system without much notice? maybe?)
I’m sorry to be asking so many questions, but I’m trying to make things work better, and not doing well on my own. Since I got the keyboard to flash a few weeks ago, it hasn’t gone well. Along with this video issue, the keyboard really doesn’t seem better. It still needs to be reset frequently, and the system sometimes doesn’t shut down when I select “systemctl poweroff” or shut down from the menu, the oled sometimes still shows “on”
I’m a bit frustrated, but I’ll try hard to work through the issues. I will not, however be able to bring it to next week’s HOPE conference as I had desired. I can’t depend on it to do a presentation in the state that it’s in.
