SD card fails to read, R30 board
The SD reader fails to read the contents of any SD card I put on it.
Flashing the lpc firmware into the board OR hitting the “reset USB (u)” option on the keyboard OLED fixes it, for 5 minutes or so (actually, this last one seems to do nothing, i don’t know why it worked for a few minutes).
$ sudo reform-check
I: Contents of /proc/device-tree/model: MNT Reform 2 with RCORE-DSI RK3588 Module
I: `uname -a` output: Linux luzzy-mnt 7.1.3-mnt-reform-arm64 #1 SMP PREEMPT Debian 7.1.3-1+reform20260705T102633Z (2026-07-05 aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 7.1.3-1+reform20260705T102633Z
I: Version of reform-tools: 1.87-1+reform20260529T225830Z+1
I: Version of system image: System Image v5: 2026-06-05
I: Version of LPC firmware: MREF2LPC 30_R1 2351811
I: Version of upstream U-Boot: 2024.10
I: Version of MNT U-Boot: 2026-01-28
I: Mount source of /boot: /dev/mmcblk0p1 (eMMC)
I: Recommends of reform-desktop-minimal is not installed: reform-qcacld2
I: eMMC contains the latest bootloader version 2026-01-28
Here is what happens when an SD card with the provided system .img written to it is inserted while powering on:
I have the same error for my newly installed R3.0 mainboard. I can’t test the “reset USB (u)” option, because my keyboard-fw ist like from 2021, when I got the reform.
Over at mastodon, @minute suspected that the problem is the recent (yesterday) kernel upgrade 7.1.3. The easiest way to check whether that’s the culprit, you could try flashing an old system image with kernel 7.0.10 to an sd-card and check if that works better:
I’m running on Debian 7.0.13-1+reform20260602T222813Z with this error.
I tried this, on first boot from this image i got to see the background and followed the setup wizard, then the screen got full of read errors.
I powered off and on again, only read errors this time, not a single [OK], ended up in initramfs again like in the picture.
And the “reset USB” thing, I tried it again and it did nothing to fix the SD card reader, not even temporarily.
I tried this system image from 7 months ago. It seems to work correctly with the SD card reader. I booted into it, finished the setup wizard, got into GNOME and ran a 1000 sample 10mb benchmark on the card. No read errors, consistent 19MB/s read. So maybe it is the kernel? This image uses Kernel 6.17.7.
If the issue does not happen for you with 6.17.7 but it does happen with 7.1.3 with the same sd-card then it indeed does sound like a kernel regression.
May I ask you @meluzzy and @max which sd-cards you are using? I have tried with these:
  • SanDisk Extreme Plus (sdxc)
  • SanDisk Ultra (sdhc)
  • SanDisk Ultra Plus (sdhc)
  • MediaRange (sdxc)
  • store.it 32gb (microsd sdhc)
I’m unable to reproduce the issue. Here is the dmesg output for the store.it sd-card with kernel 7.1.3 on rk3588 with motherboard 3.0:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 7.1.3-mnt-reform-arm64 (debian-kernel@lists.debian.org) (aarch64-linux-gnu-gcc-15 (Debian 15.3.0-1) 15.3.0, GNU ld (GNU Binutils for Debian) 2.46.50.20260617) #1 SMP PREEMPT Debian 7.1.3-1+reform20260705T102633Z (2026-07-05
[    0.000000] KASLR enabled
[    0.000000] Machine model: MNT Reform 2 with RCORE-DSI RK3588 Module
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: 0x000000000010f000..0x000000000010f0ff (0 KiB) nomap non-reusable shmem@10f000
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000004ffffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x4fdf5dbc0-0x4fdf613bf]
[    0.000000] cma: Reserved 256 MiB at 0x00000000da800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000004ffffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000003fbffffff]
[    0.000000]   node   0: [mem 0x00000003fc500000-0x00000003ffefffff]
[    0.000000]   node   0: [mem 0x00000004f0000000-0x00000004ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000004ffffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 1280 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[    0.000000] percpu: Embedded 36 pages/cpu s108888 r8192 d30376 u147456
[    0.000000] pcpu-alloc: s108888 r8192 d30376 u147456 alloc=36*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GICv3 CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off console=ttyS2,1500000 cma=256M swiotlb=65535 console=tty1
[    0.000000] PCIe ASPM is disabled
[    0.000000] printk: log buffer data + meta data: 131072 + 557056 = 688128 bytes
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000d2800000-0x00000000da800000] (128MB)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4192256
[    0.000000] Policy zone: Normal
[    0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] ftrace: allocating 57388 entries in 226 pages
[    0.000000] ftrace: allocated 226 pages with 4 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: enabling workaround for GICv3: non-coherent attribute
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 480 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [424:479]
[    0.000000] GICv3: Using MBI frame 0x00000000fe610000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTLR.DS=0, SCR_EL3.FIQ=0
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[    0.000000] ITS [mem 0xfe640000-0xfe65ffff]
[    0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001
[    0.000000] GIC: enabling workaround for ITS: non-coherent attribute
[    0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100260000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100270000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] ITS [mem 0xfe660000-0xfe67ffff]
[    0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100290000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1002a0000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] GICv3: using LPI property table @0x00000001002b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000001002c0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu@300[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/cpu@700[7] }
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.003607] Console: colour dummy device 80x25
[    0.003625] printk: legacy console [tty1] enabled
[    0.005673] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.005713] pid_max: default: 32768 minimum: 301
[    0.010109] landlock: Up and running.
[    0.010132] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.010498] AppArmor: AppArmor initialized
[    0.010608] TOMOYO Linux initialized
[    0.011268] LSM support for eBPF active
[    0.013691] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.013766] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.014941] VFS: Finished mounting rootfs on nullfs
[    0.023419] rcu: Hierarchical SRCU implementation.
[    0.023445] rcu: 	Max phase no-delay instances is 1000.
[    0.023862] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.025453] fsl-mc MSI: msi-controller@fe640000 domain created
[    0.025498] fsl-mc MSI: msi-controller@fe660000 domain created
[    0.030939] EFI services will not be available.
[    0.031691] smp: Bringing up secondary CPUs ...
[    0.032637] Detected VIPT I-cache on CPU1
[    0.032955] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[    0.032975] GICv3: CPU1: using allocated LPI pending table @0x00000001002d0000
[    0.033032] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.034226] Detected VIPT I-cache on CPU2
[    0.034534] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[    0.034551] GICv3: CPU2: using allocated LPI pending table @0x00000001002e0000
[    0.034602] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.035759] Detected VIPT I-cache on CPU3
[    0.036068] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[    0.036085] GICv3: CPU3: using allocated LPI pending table @0x00000001002f0000
[    0.036134] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.037294] CPU features: detected: Spectre-v4
[    0.037302] CPU features: detected: Spectre-BHB
[    0.037309] CPU features: detected: Broken broadcast TLBI completion
[    0.037312] CPU features: detected: SSBS not fully self-synchronizing
[    0.037314] Detected PIPT I-cache on CPU4
[    0.037452] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[    0.037461] GICv3: CPU4: using allocated LPI pending table @0x0000000100300000
[    0.037490] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[    0.038567] Detected PIPT I-cache on CPU5
[    0.038716] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[    0.038726] GICv3: CPU5: using allocated LPI pending table @0x0000000100310000
[    0.038758] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[    0.039813] Detected PIPT I-cache on CPU6
[    0.039959] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[    0.039969] GICv3: CPU6: using allocated LPI pending table @0x0000000100320000
[    0.039999] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[    0.041047] Detected PIPT I-cache on CPU7
[    0.041193] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[    0.041203] GICv3: CPU7: using allocated LPI pending table @0x0000000100330000
[    0.041232] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[    0.041357] smp: Brought up 1 node, 8 CPUs
[    0.041720] SMP: Total of 8 processors activated.
[    0.041737] CPU: All CPU(s) started at EL2
[    0.041754] CPU features: detected: 32-bit EL0 Support
[    0.041771] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.041794] CPU features: detected: Common not Private translations
[    0.041811] CPU features: detected: CRC32 instructions
[    0.041827] CPU features: detected: Data cache clean to Point of Persistence
[    0.041853] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.041871] CPU features: detected: LSE atomic instructions
[    0.041889] CPU features: detected: Privileged Access Never
[    0.041905] CPU features: detected: PMUv3
[    0.041920] CPU features: detected: RAS Extension Support
[    0.041940] CPU features: detected: XNX
[    0.041958] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.042065] alternatives: applying system-wide alternatives
[    0.046540] CPU features: detected: ICV_DIR_EL1 trapping
[    0.046569] CPU features: detected: Hardware dirty bit management on CPU4-7
[    0.080622] node 0 deferred pages initialised in 32ms
[    0.080687] Memory: 15963748K/16769024K available (19392K kernel code, 5190K rwdata, 11740K rodata, 3840K init, 917K bss, 534760K reserved, 262144K cma-reserved)
[    0.083177] devtmpfs: initialized
[    0.097684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.097720] posixtimers hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.097777] futex hash table entries: 2048 (131072 bytes on 1 NUMA nodes, total 128 KiB, linear).
[    0.099253] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.099269] 0 pages in range for non-PLT usage
[    0.099272] 513952 pages in range for PLT usage
[    0.103137] DMI: not present or invalid.
[    0.105820] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.106719] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.107156] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.107185] audit: initializing netlink subsys (disabled)
[    0.107289] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[    0.110011] thermal_sys: Registered thermal governor 'fair_share'
[    0.110018] thermal_sys: Registered thermal governor 'bang_bang'
[    0.110028] thermal_sys: Registered thermal governor 'step_wise'
[    0.110035] thermal_sys: Registered thermal governor 'user_space'
[    0.110041] thermal_sys: Registered thermal governor 'power_allocator'
[    0.110088] cpuidle: using governor ladder
[    0.110123] cpuidle: using governor menu
[    0.110271] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.110430] ASID allocator initialised with 32768 entries
[    0.111591] Serial: AMBA PL011 UART driver
[    0.127880] /vop@fdd90000: Fixed dependency cycle(s) with /dsi@fde30000
[    0.127924] /dsi@fde30000: Fixed dependency cycle(s) with /vop@fdd90000
[    0.134989] /pcie@fe180000: Fixed dependency cycle(s) with /pcie@fe180000/legacy-interrupt-controller
[    0.135368] /pcie@fe190000: Fixed dependency cycle(s) with /pcie@fe190000/legacy-interrupt-controller
[    0.140197] /i2c@fec80000/bridge@2c: Fixed dependency cycle(s) with /i2c@fec80000/bridge@2c/aux-bus/panel
[    0.140225] /i2c@fec80000/bridge@2c: Fixed dependency cycle(s) with /dsi@fde30000
[    0.140274] /i2c@fec80000/bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /i2c@fec80000/bridge@2c
[    0.140296] /i2c@fec80000/codec@1a: Fixed dependency cycle(s) with /i2s@fe470000
[    0.145248] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[    0.145707] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[    0.146147] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[    0.146617] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[    0.147136] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[    0.149473] /vop@fdd90000: Fixed dependency cycle(s) with /hdmi@fdea0000
[    0.149521] /hdmi@fdea0000: Fixed dependency cycle(s) with /vop@fdd90000
[    0.150127] /pcie@fe150000: Fixed dependency cycle(s) with /pcie@fe150000/legacy-interrupt-controller
[    0.160416] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.160431] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.160439] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.160446] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.160453] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.160460] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.160467] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.160473] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.168174] ACPI: Interpreter disabled.
[    0.170671] iommu: Default domain type: Translated
[    0.170681] iommu: DMA domain TLB invalidation policy: strict mode
[    0.171900] pps_core: LinuxPPS API ver. 1 registered
[    0.171910] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.171923] PTP clock support registered
[    0.171960] EDAC MC: Ver: 3.0.0
[    0.172215] scmi_core: SCMI protocol bus registered
[    0.173727] NetLabel: Initializing
[    0.173737] NetLabel:  domain hash size = 128
[    0.173743] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.173785] NetLabel:  unlabeled traffic allowed by default
[    0.173918] vgaarb: loaded
[    0.174225] clocksource: Switched to clocksource arch_sys_counter
[    0.176014] VFS: Disk quotas dquot_6.6.0
[    0.176185] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.176875] AppArmor: AppArmor Filesystem Enabled
[    0.176967] pnp: PnP ACPI: disabled
[    0.181997] NET: Registered PF_INET protocol family
[    0.182353] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.192868] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.193030] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.193161] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.194377] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.196268] TCP: Hash tables configured (established 131072 bind 65536)
[    0.196552] MPTCP token hash table entries: 16384 (order: 7, 393216 bytes, linear)
[    0.196815] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.197549] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.197577] NET: Registered PF_XDP protocol family
[    0.197593] PCI: CLS 0 bytes, default 64
[    0.197743] Trying to unpack rootfs image as initramfs...
[    0.208793] kvm [1]: nv: 570 coarse grained trap handlers
[    0.208935] kvm [1]: nv: 710 fine grained trap handlers
[    0.209203] kvm [1]: IPA Size Limit: 40 bits
[    0.209239] kvm [1]: GICv3: no GICV resource entry
[    0.209247] kvm [1]: disabling GICv2 emulation
[    0.209281] kvm [1]: GIC system register CPU interface enabled
[    0.209360] kvm [1]: vgic interrupt IRQ9
[    0.209396] kvm [1]: VHE mode initialized successfully
[    0.215846] Initialise system trusted keyrings
[    0.215903] Key type blacklist registered
[    0.216140] workingset: timestamp_bits=42 (anon: 38) max_order=22 bucket_order=0 (anon: 0)
[    0.220583] fuse: init (API version 7.45)
[    0.221384] integrity: Platform Keyring initialized
[    0.221409] integrity: Machine keyring initialized
[    0.221466] Key type asymmetric registered
[    0.221473] Asymmetric key parser 'x509' registered
[    0.221629] alg: self-tests disabled
[    0.221907] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.222079] io scheduler mq-deadline registered
[    0.250399] ledtrig-cpu: registered to indicate activity on CPUs
[    0.264290] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.264313] dma-pl330 fea10000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.265575] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.265592] dma-pl330 fea30000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.266722] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.266740] dma-pl330 fed10000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.272924] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.274605] printk: legacy console [ttyS2] disabled
[    0.274835] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 27, base_baud = 1500000) is a 16550A
[    0.274901] printk: legacy console [ttyS2] enabled
[    0.420411] Serial: AMBA driver
[    0.421522] msm_serial: driver initialized
[    0.422386] SuperH (H)SCI(F) driver initialized
[    0.424617] arm-smmu-v3 fc900000.iommu: oas 48-bit (features 0x001c1ebf)
[    0.426942] arm-smmu-v3 fc900000.iommu: allocated 65536 entries for cmdq
[    0.430661] arm-smmu-v3 fc900000.iommu: allocated 32768 entries for evtq
[    0.431935] arm-smmu-v3 fc900000.iommu: allocated 65536 entries for priq
[    0.434686] arm-smmu-v3 fc900000.iommu: msi_domain absent - falling back to wired irqs
[    0.437081] platform fdb50000.video-codec: Adding to iommu group 0
[    0.438518] platform fdba0000.video-codec: Adding to iommu group 1
[    0.439857] platform fdba4000.video-codec: Adding to iommu group 2
[    0.441185] platform fdba8000.video-codec: Adding to iommu group 3
[    0.442522] platform fdbac000.video-codec: Adding to iommu group 4
[    0.443506] rockchip-pm-domain fd8d8000.power-management:power-controller: supply domain not found, using dummy regulator
[    0.445027] platform fdc38100.video-codec: Adding to iommu group 5
[    0.446441] platform fdc40100.video-codec: Adding to iommu group 6
[    0.447656] platform fdd90000.vop: Adding to iommu group 7
[    0.464975] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7
[    0.465869] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs1_pwrdn
[    0.466710] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs3_null
[    0.467524] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs2_null
[    0.468337] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins
[    0.470332] mousedev: PS/2 mouse device common for all mice
[    0.475413] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
[    0.475935] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20
[    0.476834] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    0.477624] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
[    0.478297] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.479037] arm-scmi arm-scmi.0.auto: Enabling SCMI Quirk [quirk_clock_rates_triplet_out_of_spec]
[    0.481348] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.486681] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    0.490533] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
[    0.495867] NET: Registered PF_INET6 protocol family
[    0.498067] Segment Routing with IPv6
[    0.498413] RPL Segment Routing with IPv6
[    0.498793] In-situ OAM (IOAM) with IPv6
[    0.499176] mip6: Mobile IPv6
[    0.499445] NET: Registered PF_PACKET protocol family
[    0.500227] mpls_gso: MPLS GSO support
[    0.507594] registered taskstats version 1
[    0.508151] Loading compiled-in X.509 certificates
[    0.679923] Freeing initrd memory: 39244K
[    0.711940] Loaded X.509 cert 'Build time autogenerated kernel key: 6df29ac8a778d892b2b6519a1d80c5f5b5595d36'
[    0.720159] Demotion targets for Node 0: null
[    0.720838] Key type .fscrypt registered
[    0.721188] Key type fscrypt-provisioning registered
[    0.798250] Key type encrypted registered
[    0.798626] AppArmor: AppArmor sha256 policy hashing enabled
[    0.799130] ima: No TPM chip found, activating TPM-bypass!
[    0.799616] ima: Allocated hash algorithm: sha256
[    0.800794] ima: No architecture policies found
[    0.801268] evm: Initialising EVM extended attributes:
[    0.801722] evm: security.selinux
[    0.802017] evm: security.SMACK64 (disabled)
[    0.802411] evm: security.SMACK64EXEC (disabled)
[    0.802818] evm: security.SMACK64TRANSMUTE (disabled)
[    0.803262] evm: security.SMACK64MMAP (disabled)
[    0.803668] evm: security.apparmor
[    0.803970] evm: security.ima
[    0.804232] evm: security.capability
[    0.804548] evm: HMAC attrs: 0x1
[    0.850737] clk: Disabling unused clocks
[    0.851816] PM: genpd: Disabling unused power domains
[    0.858761] Freeing unused kernel memory: 3840K
[    0.985577] Checked W+X mappings: passed, no W+X pages found
[    0.986098] Run /init as init process
[    0.986434]   with arguments:
[    0.986439]     /init
[    0.986443]   with environment:
[    0.986446]     HOME=/
[    0.986449]     TERM=linux
[    2.105689] /dsi@fde30000: Fixed dependency cycle(s) with /i2c@fec80000/bridge@2c
[    2.106647] /i2c@fec80000/bridge@2c: Fixed dependency cycle(s) with /i2c@fec80000/bridge@2c/aux-bus/panel
[    2.107550] /i2c@fec80000/bridge@2c: Fixed dependency cycle(s) with /dsi@fde30000
[    2.108452] /i2c@fec80000/bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /i2c@fec80000/bridge@2c
[    2.109702] /i2s@fe470000: Fixed dependency cycle(s) with /i2c@fec80000/codec@1a
[    2.110506] /i2c@fec80000/codec@1a: Fixed dependency cycle(s) with /i2s@fe470000
[    2.120054] usbcore: registered new interface driver usbfs
[    2.120573] usbcore: registered new interface driver hub
[    2.121072] usbcore: registered new device driver usb
[    2.188078] ehci-platform fc800000.usb: EHCI Host Controller
[    2.188391] ehci-platform fc880000.usb: EHCI Host Controller
[    2.188608] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[    2.189111] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
[    2.189879] ehci-platform fc800000.usb: irq 67, io mem 0xfc800000
[    2.190605] ehci-platform fc880000.usb: irq 68, io mem 0xfc880000
[    2.202262] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[    2.203487] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    2.204222] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.204859] usb usb1: Product: EHCI Host Controller
[    2.205289] usb usb1: Manufacturer: Linux 7.1.3-mnt-reform-arm64 ehci_hcd
[    2.205884] usb usb1: SerialNumber: fc800000.usb
[    2.214454] hub 1-0:1.0: USB hub found
[    2.214831] hub 1-0:1.0: 1 port detected
[    2.218260] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[    2.218948] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    2.219678] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.220313] usb usb2: Product: EHCI Host Controller
[    2.220743] usb usb2: Manufacturer: Linux 7.1.3-mnt-reform-arm64 ehci_hcd
[    2.221338] usb usb2: SerialNumber: fc880000.usb
[    2.241334] hub 2-0:1.0: USB hub found
[    2.241824] hub 2-0:1.0: 1 port detected
[    2.265245] ohci-platform fc840000.usb: Generic Platform OHCI controller
[    2.265420] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[    2.265860] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
[    2.266482] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
[    2.266577] ohci-platform fc8c0000.usb: irq 70, io mem 0xfc8c0000
[    2.267222] ohci-platform fc840000.usb: irq 69, io mem 0xfc840000
[    2.323584] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.325017] rockchip-dw-pcie a40c00000.pcie: host bridge /pcie@fe180000 ranges:
[    2.325698] rockchip-dw-pcie a40c00000.pcie:       IO 0x00f3100000..0x00f31fffff -> 0x00f3100000
[    2.326476] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 7.01
[    2.326487] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.326492] usb usb4: Product: Generic Platform OHCI controller
[    2.326550] rockchip-dw-pcie a40c00000.pcie:      MEM 0x00f3200000..0x00f3ffffff -> 0x00f3200000
[    2.327228] usb usb4: Manufacturer: Linux 7.1.3-mnt-reform-arm64 ohci_hcd
[    2.327236] rockchip-dw-pcie a40c00000.pcie:      MEM 0x09c0000000..0x09ffffffff -> 0x09c0000000
[    2.327243] usb usb4: SerialNumber: fc8c0000.usb
[    2.327395] rockchip-dw-pcie a40c00000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.328356] hub 4-0:1.0: USB hub found
[    2.332026] hub 4-0:1.0: 1 port detected
[    2.332884] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 7.01
[    2.333655] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.334197] reform2_lpc: loading out-of-tree module taints kernel.
[    2.334347] usb usb3: Product: Generic Platform OHCI controller
[    2.334882] reform2_lpc: module verification failed: signature and/or required key missing - tainting kernel
[    2.334896] usb usb3: Manufacturer: Linux 7.1.3-mnt-reform-arm64 ohci_hcd
[    2.336891] usb usb3: SerialNumber: fc840000.usb
[    2.338245] hub 3-0:1.0: USB hub found
[    2.338685] hub 3-0:1.0: 1 port detected
[    2.353929] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    2.354603] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    2.355188] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    2.355713] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 74,32 bit host data width,256 deep fifo
[    2.356697] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO
[    2.369849] mmc_host mmc1: Bus speed = 400000Hz (req 400000Hz, actual 400000HZ div = 0)
[    2.400918] mmc0: CQHCI version 5.10
[    2.458259] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[    2.470279] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    2.490297] mmc_host mmc1: Bus speed = 39600000Hz (req 40000000Hz, actual 39600000HZ div = 0)
[    2.492522] rk_gmac-dwmac fe1b0000.ethernet: IRQ sfty not found
[    2.493385] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[    2.494018] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x10).
[    2.494556] rk_gmac-dwmac fe1b0000.ethernet: RX delay(0x10).
[    2.495061] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[    2.498274] mmc1: new high speed SDHC card at address b369
[    2.500625] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII
[    2.501832] mmcblk1: mmc1:b369 SDABC 29.1 GiB
[    2.506737]  mmcblk1: p1 p2
[    2.508103] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    2.508745] rk_gmac-dwmac fe1b0000.ethernet: 	DWMAC4/5
[    2.509201] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[    2.509859] rk_gmac-dwmac fe1b0000.ethernet: Active PHY interface: RGMII (1)
[    2.510498] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[    2.511156] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[    2.511774] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[    2.512390] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.513099] rk_gmac-dwmac fe1b0000.ethernet: Enabled L3L4 Flow TC (entries=2)
[    2.513733] rk_gmac-dwmac fe1b0000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.514385] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[    2.514870] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[    2.515398] rk_gmac-dwmac fe1b0000.ethernet: SPH feature enabled
[    2.515926] rk_gmac-dwmac fe1b0000.ethernet: Using 32/32 bits DMA host/device width
[    2.516088] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected!
[    2.517332] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected!
[    2.517772] fan53555-regulator 1-0042: FAN53555 Option[10] Rev[1] Detected!
[    2.537234] rtc-pcf8523 6-0068: registered as rtc0
[    2.538969] rtc-pcf8523 6-0068: setting system clock to 2026-07-07T03:59:14 UTC (1783396754)
[    2.567010] sdhci-dwcmshc fe2e0000.mmc: Can't reduce the clock below 52MHz in HS200/HS400 mode
[    2.568946] mmc0: Command Queue Engine enabled
[    2.569356] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.570783] mmcblk0: mmc0:0001 Y0S256 233 GiB
[    2.572406]  mmcblk0: p1 p2
[    2.573110] mmcblk0boot0: mmc0:0001 Y0S256 4.00 MiB
[    2.575666] mmcblk0boot1: mmc0:0001 Y0S256 4.00 MiB
[    2.577488] mmcblk0rpmb: mmc0:0001 Y0S256 16.0 MiB, chardev (236:0)
[    2.619585] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    2.620322] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    2.620951] usb 1-1: SerialNumber: 9C0B20791EA6
[    2.621933] hub 1-1:1.0: USB hub found
[    2.622458] hub 1-1:1.0: 4 ports detected
[    2.657751] usbcore: registered new device driver onboard-usb-dev
[    2.717563] rk_gmac-dwmac fe1b0000.ethernet end0: renamed from eth0
[    2.902445] usb 1-1.3: new full-speed USB device number 3 using ehci-platform
[    3.024979] hid: raw HID events driver (C) Jiri Kosina
[    3.046501] usbcore: registered new interface driver usbhid
[    3.047005] usbhid: USB HID core driver
[    3.097163] usb 1-1.3: New USB device found, idVendor=1209, idProduct=6d02, bcdDevice= 1.00
[    3.097916] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.098580] usb 1-1.3: Product: MNT Reform Keyboard 4.0 Neo2/LT
[    3.099101] usb 1-1.3: Manufacturer: MNT Research
[    3.099517] usb 1-1.3: SerialNumber: RP2040
[    3.188454] input: MNT Research MNT Reform Keyboard 4.0 Neo2/LT Keyboard as /devices/platform/fc800000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1209:6D02.0001/input/input1
[    3.209379] usb 1-1.4: new full-speed USB device number 4 using ehci-platform
[    3.303876] mc: Linux media interface: v0.10
[    3.309459] usb 1-1.4: New USB device found, idVendor=cafe, idProduct=4008, bcdDevice= 1.00
[    3.310209] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.310871] usb 1-1.4: Product: Reform Trackball (RP2040)
[    3.311348] usb 1-1.4: Manufacturer: MNT Research
[    3.311763] usb 1-1.4: SerialNumber: MREFATBC20R02
[    3.314813] input: MNT Research Reform Trackball (RP2040) as /devices/platform/fc800000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:CAFE:4008.0002/input/input2
[    3.326925] hid-generic 0003:1209:6D02.0001: input,hidraw0: USB HID v1.11 Keyboard [MNT Research MNT Reform Keyboard 4.0 Neo2/LT] on usb-fc800000.usb-1.3/input0
[    3.327291] hid-generic 0003:CAFE:4008.0002: input,hidraw1: USB HID v1.11 Mouse [MNT Research Reform Trackball (RP2040)] on usb-fc800000.usb-1.4/input0
[    3.372266] videodev: Linux video capture interface: v2.00
[    3.402257] rockchip-dw-pcie a40c00000.pcie: Device found, but not active
[    3.403153] rockchip-dw-pcie a40c00000.pcie: PCI host bridge to bus 0003:30
[    3.403774] pci_bus 0003:30: root bus resource [bus 30-3f]
[    3.404261] pci_bus 0003:30: root bus resource [io  0x0000-0xfffff] (bus address [0xf3100000-0xf31fffff])
[    3.405101] pci_bus 0003:30: root bus resource [mem 0xf3200000-0xf3ffffff]
[    3.405705] pci_bus 0003:30: root bus resource [mem 0x9c0000000-0x9ffffffff]
[    3.406368] pci 0003:30:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port
[    3.407026] pci 0003:30:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    3.407573] pci 0003:30:00.0: PCI bridge to [bus 01-ff]
[    3.408036] pci 0003:30:00.0:   bridge window [io  0x0000-0x0fff]
[    3.408574] pci 0003:30:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    3.409175] pci 0003:30:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    3.409898] pci 0003:30:00.0: supports D1 D2
[    3.410283] pci 0003:30:00.0: PME# supported from D0 D1 D3hot
[    3.414332] pci 0003:30:00.0: Adding to iommu group 8
[    3.417514] pci 0003:30:00.0: Primary bus is hard wired to 0
[    3.418023] pci 0003:30:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring
[    3.418914] pci_bus 0003:31: busn_res: [bus 31-3f] end is updated to 31
[    3.419514] pci 0003:30:00.0: ROM [mem 0xf3200000-0xf320ffff pref]: assigned
[    3.420139] pci 0003:30:00.0: PCI bridge to [bus 31]
[    3.420582] pci_bus 0003:30: resource 4 [io  0x0000-0xfffff]
[    3.421081] pci_bus 0003:30: resource 5 [mem 0xf3200000-0xf3ffffff]
[    3.421633] pci_bus 0003:30: resource 6 [mem 0x9c0000000-0x9ffffffff]
[    3.424231] pcieport 0003:30:00.0: PME: Signaling with IRQ 88
[    3.425220] pcieport 0003:30:00.0: AER: enabled with IRQ 89
[    3.446766] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.462151] rockchip-dw-pcie a41000000.pcie: host bridge /pcie@fe190000 ranges:
[    3.462905] rockchip-dw-pcie a41000000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[    3.463720] rockchip-dw-pcie a41000000.pcie:      MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000
[    3.464520] rockchip-dw-pcie a41000000.pcie:      MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000
[    3.465625] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    3.509148] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    3.509657] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[    3.510457] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    3.511311] xhci-hcd xhci-hcd.4.auto: irq 90, io mem 0xfc000000
[    3.511941] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    3.512429] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[    3.513105] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[    3.514007] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    3.514763] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.515400] usb usb5: Product: xHCI Host Controller
[    3.515831] usb usb5: Manufacturer: Linux 7.1.3-mnt-reform-arm64 xhci-hcd
[    3.516427] usb usb5: SerialNumber: xhci-hcd.4.auto
[    3.517536] hub 5-0:1.0: USB hub found
[    3.517919] hub 5-0:1.0: 1 port detected
[    3.519417] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.520720] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[    3.521463] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.522100] usb usb6: Product: xHCI Host Controller
[    3.522544] usb usb6: Manufacturer: Linux 7.1.3-mnt-reform-arm64 xhci-hcd
[    3.523142] usb usb6: SerialNumber: xhci-hcd.4.auto
[    3.524397] hub 6-0:1.0: USB hub found
[    3.524788] hub 6-0:1.0: 1 port detected
[    3.525579] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    3.526077] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 7
[    3.526908] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    3.527761] xhci-hcd xhci-hcd.5.auto: irq 91, io mem 0xfc400000
[    3.528392] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    3.528879] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 8
[    3.529553] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[    3.531061] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    3.531808] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.532445] usb usb7: Product: xHCI Host Controller
[    3.532876] usb usb7: Manufacturer: Linux 7.1.3-mnt-reform-arm64 xhci-hcd
[    3.533472] usb usb7: SerialNumber: xhci-hcd.5.auto
[    3.534601] hub 7-0:1.0: USB hub found
[    3.535153] hub 7-0:1.0: 1 port detected
[    3.536020] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.536889] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[    3.537618] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.538269] usb usb8: Product: xHCI Host Controller
[    3.538700] usb usb8: Manufacturer: Linux 7.1.3-mnt-reform-arm64 xhci-hcd
[    3.539297] usb usb8: SerialNumber: xhci-hcd.5.auto
[    3.540324] hub 8-0:1.0: USB hub found
[    3.540687] hub 8-0:1.0: 1 port detected
[    3.670300] rockchip-dw-pcie a41000000.pcie: PCIe Gen.1 x1 link up
[    3.671128] rockchip-dw-pcie a41000000.pcie: PCI host bridge to bus 0004:40
[    3.671782] pci_bus 0004:40: root bus resource [bus 40-4f]
[    3.672290] pci_bus 0004:40: root bus resource [io  0x100000-0x1fffff] (bus address [0xf4100000-0xf41fffff])
[    3.673172] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff]
[    3.673834] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff]
[    3.674549] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port
[    3.675243] pci 0004:40:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    3.675819] pci 0004:40:00.0: PCI bridge to [bus 01-ff]
[    3.676309] pci 0004:40:00.0:   bridge window [io  0x0000-0x0fff]
[    3.676867] pci 0004:40:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    3.677524] pci 0004:40:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    3.678314] pci 0004:40:00.0: supports D1 D2
[    3.678710] pci 0004:40:00.0: PME# supported from D0 D1 D3hot
[    3.680558] pci 0004:40:00.0: Adding to iommu group 9
[    3.688808] pci 0004:40:00.0: Primary bus is hard wired to 0
[    3.689335] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring
[    3.690461] pci 0004:41:00.0: [168c:002a] type 00 class 0x028000 PCIe Legacy Endpoint
[    3.691416] pci 0004:41:00.0: BAR 0 [mem 0x00000000-0x0000ffff 64bit]
[    3.692455] pci 0004:41:00.0: supports D1
[    3.692828] pci 0004:41:00.0: PME# supported from D0 D1 D3hot
[    3.694620] pci 0004:41:00.0: Adding to iommu group 9
[    3.695219] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41
[    3.695857] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff]: assigned
[    3.696550] pci 0004:40:00.0: ROM [mem 0xf4300000-0xf430ffff pref]: assigned
[    3.697200] pci 0004:41:00.0: BAR 0 [mem 0xf4200000-0xf420ffff 64bit]: assigned
[    3.697946] pci 0004:40:00.0: PCI bridge to [bus 41]
[    3.698433] pci 0004:40:00.0:   bridge window [mem 0xf4200000-0xf42fffff]
[    3.699057] pci_bus 0004:40: resource 4 [io  0x100000-0x1fffff]
[    3.699603] pci_bus 0004:40: resource 5 [mem 0xf4200000-0xf4ffffff]
[    3.700173] pci_bus 0004:40: resource 6 [mem 0xa00000000-0xa3fffffff]
[    3.700758] pci_bus 0004:41: resource 1 [mem 0xf4200000-0xf42fffff]
[    3.705971] pcieport 0004:40:00.0: PME: Signaling with IRQ 102
[    3.707447] pcieport 0004:40:00.0: AER: enabled with IRQ 103
[    3.710772] rockchip-dw-pcie a40000000.pcie: host bridge /pcie@fe150000 ranges:
[    3.711483] rockchip-dw-pcie a40000000.pcie:       IO 0x00f0100000..0x00f01fffff -> 0x00f0100000
[    3.712295] rockchip-dw-pcie a40000000.pcie:      MEM 0x00f0200000..0x00f0ffffff -> 0x00f0200000
[    3.713095] rockchip-dw-pcie a40000000.pcie:      MEM 0x0900000000..0x093fffffff -> 0x0900000000
[    3.721913] rockchip-dw-pcie a40000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    3.882273] usb 8-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.903565] usb 8-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[    3.904335] usb 8-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.930743] hub 8-1:1.0: USB hub found
[    3.931290] hub 8-1:1.0: 4 ports detected
[    4.030313] rockchip-dw-pcie a40000000.pcie: PCIe Gen.3 x4 link up
[    4.031157] rockchip-dw-pcie a40000000.pcie: PCI host bridge to bus 0000:00
[    4.031813] pci_bus 0000:00: root bus resource [bus 00-0f]
[    4.032319] pci_bus 0000:00: root bus resource [io  0x200000-0x2fffff] (bus address [0xf0100000-0xf01fffff])
[    4.033201] pci_bus 0000:00: root bus resource [mem 0xf0200000-0xf0ffffff]
[    4.033866] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff]
[    4.034708] pci 0000:00:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port
[    4.035467] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    4.036058] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    4.036544] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    4.037101] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    4.037755] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    4.038542] pci 0000:00:00.0: supports D1 D2
[    4.038938] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    4.040895] pci 0000:00:00.0: Adding to iommu group 10
[    4.049383] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    4.050575] pci 0000:01:00.0: [1e4b:1202] type 00 class 0x010802 PCIe Endpoint
[    4.051396] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[    4.052399] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    4.054449] pci 0000:01:00.0: Adding to iommu group 10
[    4.055124] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff]: assigned
[    4.055828] pci 0000:00:00.0: ROM [mem 0xf0300000-0xf030ffff pref]: assigned
[    4.056478] pci 0000:01:00.0: BAR 0 [mem 0xf0200000-0xf0203fff 64bit]: assigned
[    4.057175] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    4.057705] pci 0000:00:00.0:   bridge window [mem 0xf0200000-0xf02fffff]
[    4.058356] pci_bus 0000:00: resource 4 [io  0x200000-0x2fffff]
[    4.058900] pci_bus 0000:00: resource 5 [mem 0xf0200000-0xf0ffffff]
[    4.059480] pci_bus 0000:00: resource 6 [mem 0x900000000-0x93fffffff]
[    4.060067] pci_bus 0000:01: resource 1 [mem 0xf0200000-0xf02fffff]
[    4.065377] pcieport 0000:00:00.0: PME: Signaling with IRQ 114
[    4.067488] pcieport 0000:00:00.0: AER: enabled with IRQ 115
[    4.077028] cpufreq: cpufreq_policy_online: CPU0: Running at unlisted initial frequency: 816000 kHz, changing to: 1008000 kHz
[    4.078291] cpu cpu0: EM: created perf domain
[    4.081905] cpufreq: cpufreq_policy_online: CPU4: Running at unlisted initial frequency: 816000 kHz, changing to: 1200000 kHz
[    4.083064] cpu cpu4: EM: created perf domain
[    4.084033] Key type psk registered
[    4.086653] cpufreq: cpufreq_policy_online: CPU6: Running at unlisted initial frequency: 816000 kHz, changing to: 1200000 kHz
[    4.087797] cpu cpu6: EM: created perf domain
[    4.088189] energy_model: updating cpu0 cpu_cap=397 old capacity=530
[    4.097950] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops [rockchipdrm])
[    4.099462] dwhdmiqp-rockchip fdea0000.hdmi: registered DesignWare HDMI QP I2C bus driver
[    4.100492] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops dw_hdmi_qp_rockchip_ops [rockchipdrm])
[    4.101554] rockchip-drm display-subsystem: bound fde30000.dsi (ops dw_mipi_dsi2_rockchip_ops [rockchipdrm])
[    4.110582] nvme nvme0: pci function 0000:01:00.0
[    4.111009] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    4.120728] hwmon hwmon1: temp1_input not attached to any thermal zone
[    4.121351] hwmon hwmon1: temp2_input not attached to any thermal zone
[    4.121957] hwmon hwmon1: temp3_input not attached to any thermal zone
[    4.122555] nvme nvme0: passthrough uses implicit buffer lengths
[    4.123945] nvme nvme0: allocated 8 MiB host memory buffer (1 segment).
[    4.126682] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0
[    4.133346] nvme nvme0: 8/0/0 default/read/poll queues
[    4.145204] nvme nvme0: Ignoring bogus Namespace Identifiers
[    4.150270] random: crng init done
[    4.225884] Console: switching to colour frame buffer device 240x67
[    4.243913] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    5.484382]  mmcblk1: p1 p2
[    7.374737]  mmcblk1: p1 p2
[   14.562645] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fb000000.gpu
[   14.563673] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdb50000.video-codec
[   14.564716] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdb80000.rga
[   14.565730] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba0000.video-codec
[   14.566808] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba4000.video-codec
[   14.567852] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba8000.video-codec
[   14.568891] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdbac000.video-codec
[   14.569955] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdc38100.video-codec
[   14.571031] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdc40100.video-codec
[   14.572108] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdc70000.video-codec
[   14.573157] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fe470000.i2s
[   14.574197] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fddf4000.i2s
[   28.169511] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
[   28.170150] EXT4-fs (mmcblk1p2): mounted filesystem da3f5551-2b95-5559-b0bc-474c2fe844d4 ro with ordered data mode. Quota mode: none.
[   28.590625] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   31.105111] systemd[1]: Inserted module 'autofs4'
[   31.933504] systemd[1]: systemd 261.1-2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +LIBARCHIVE)
[   31.937301] systemd[1]: Detected architecture arm64.
[   32.042106] systemd[1]: Initializing machine ID from random generator.
[   32.045080] systemd[1]: Installed transient '/etc/machine-id' file.
[   32.066428] systemd[1]: Hostname set to <reform>.
[   32.429751] systemd[1]: bpf-restrict-fs: Failed to load BPF object: No such process
[   36.736734] dw-apb-uart feb50000.serial: forbid DMA for kernel console
[   39.215300] systemd[1]: Queued start job for default target graphical.target.
[   39.237374] systemd[1]: Created slice system-cups.slice - CUPS Slice.
[   39.242298] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[   39.245650] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   39.250547] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   39.254098] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[   39.257343] systemd[1]: Created slice user.slice - User and Session Slice.
[   39.260054] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[   39.264510] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   39.267415] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   39.270202] systemd[1]: Expecting device dev-disk-by\x2dlabel-reformsdboot.device - /dev/disk/by-label/reformsdboot...
[   39.273074] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2...
[   39.275461] systemd[1]: Reached target imports.target - Image Downloads.
[   39.279058] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[   39.281315] systemd[1]: Reached target slices.target - Slice Units.
[   39.283249] systemd[1]: Reached target swap.target - Swaps.
[   39.285227] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[   39.287476] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[   39.323850] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[   39.331444] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
[   39.339194] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[   39.348098] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
[   39.351109] systemd[1]: Listening on systemd-hostnamed.socket - Hostname Service Socket.
[   39.355378] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   39.358336] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[   39.371325] systemd[1]: Listening on systemd-mute-console.socket - Console Output Muting Service Socket.
[   39.374476] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-os
[   39.376689] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[   39.379044] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   39.382029] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   39.384915] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
[   39.392773] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   39.397798] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   39.402612] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   39.407330] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   39.416682] systemd[1]: tmp.mount: x-systemd.graceful-option=usrquota specified, but option is not available, suppressing.
[   39.432165] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[   39.435455] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS skipped, unmet condition check ConditionPathExists=/etc/krb5.keytab
[   39.440008] systemd[1]: Starting blk-availability.service - Availability of block devices...
[   39.445653] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   39.451125] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   39.456588] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   39.462250] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   39.465615] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[   39.469791] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   39.473106] systemd[1]: modprobe@fuse.service - Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[   39.476863] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   39.481390] systemd[1]: Starting modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics...
[   39.484479] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
[   39.486880] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[   39.493219] systemd[1]: Starting systemd-journald.service - Journal Service...
[   39.528812] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   39.533446] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-os
[   39.535948] systemd[1]: systemd-pcrosseparator.service - TPM PCR OS Separator skipped, unmet condition check ConditionSecurity=measured-os
[   39.540373] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   39.543643] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-os
[   39.546991] systemd[1]: systemd-pcrnvdone.service - TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionPathExists=/etc/initrd-release
[   39.549429] systemd[1]: systemd-pcrproduct.service - TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-os
[   39.555671] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[   39.561149] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   39.690945] systemd[1]: Finished blk-availability.service - Availability of block devices.
[   39.903096] EXT4-fs (mmcblk1p2): re-mounted da3f5551-2b95-5559-b0bc-474c2fe844d4 r/w.
[   40.026458] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   40.031532] systemd-journald[461]: Collecting audit messages is disabled.
[   40.036136] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   40.043700] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   40.046838] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   40.049101] i2c_dev: i2c /dev entries driver
[   40.052541] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[   40.055565] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   40.058616] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   40.061493] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   40.063295] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   40.067515] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   40.069217] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   40.071940] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   40.074655] systemd[1]: modprobe@nvme_fabrics.service: Deactivated successfully.
[   40.076361] systemd[1]: Finished modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics.
[   40.080756] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   40.083880] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   40.087168] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[   40.092481] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   40.101345] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, no trigger condition checks were met.
[   40.103360] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/fs/pstore
[   40.106876] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   40.127525] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   40.132003] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   40.135400] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-os
[   40.137854] systemd[1]: Started systemd-journald.service - Journal Service.
[   40.209062] systemd-journald[461]: Received client request to flush runtime journal.
[   40.384770] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[   40.387109] device-mapper: uevent: version 1.0.3
[   40.388965] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[   45.502510] rockchip-pm-domain fd8d8000.power-management:power-controller: supply domain not found, using dummy regulator
[   45.504532] panthor fb000000.gpu: [drm] clock rate = 198000000
[   45.513032] panthor fb000000.gpu: EM: created perf domain
[   45.514845] panthor fb000000.gpu: [drm] Mali-G610 id 0xa867 major 0x0 minor 0x0 status 0x5
[   45.516739] panthor fb000000.gpu: [drm] Features: L2:0x7120306 Tiler:0x809 Mem:0x301 MMU:0x2830 AS:0xff
[   45.516744] panthor fb000000.gpu: [drm] shader_present=0x50005 l2_present=0x1 tiler_present=0x1
[   45.637664] rockchip-rga fdb80000.rga: HW Version: 0x03.02
[   45.641109] rockchip-rga fdb80000.rga: Registered rockchip-rga as /dev/video0
[   45.687917] rkvdec fdc40100.video-codec: missing multi-core support, ignoring this instance
[   45.695947] hantro-vpu fdb50000.video-codec: registered rockchip,rk3568-vpu-dec as /dev/video2
[   45.697922] hantro-vpu fdba0000.video-codec: registered rockchip,rk3588-vepu121-enc as /dev/video3
[   45.699828] hantro-vpu fdba4000.video-codec: missing multi-core support, ignoring this instance
[   45.701410] hantro-vpu fdba8000.video-codec: missing multi-core support, ignoring this instance
[   45.702972] hantro-vpu fdbac000.video-codec: missing multi-core support, ignoring this instance
[   45.705053] hantro-vpu fdc70000.video-codec: registered rockchip,rk3588-av1-vpu-dec as /dev/video4
[   45.848899] panthor fb000000.gpu: [drm] Firmware protected mode entry is not supported, ignoring
[   45.851003] panthor fb000000.gpu: [drm] Firmware git sha: 95a25d71030715381f33105394285e1dcc860a65
[   45.854290] panthor fb000000.gpu: [drm] CSF FW using interface v1.5.0, Features 0x0 Instrumentation features 0x71
[   45.856777] panthor fb000000.gpu: [drm] Using Transparent Hugepage
[   45.859428] [drm] Initialized panthor 1.8.0 for fb000000.gpu on minor 1
[   46.342106] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   46.346277] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   46.348536] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   46.350816] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   46.352763] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   46.768256] ath9k 0004:41:00.0: enabling device (0000 -> 0002)
[   47.206548] ath: EEPROM regdomain: 0x0
[   47.206553] ath: EEPROM indicates default country code should be used
[   47.206555] ath: doing EEPROM country->regdmn map search
[   47.206557] ath: country maps to regdmn code: 0x3a
[   47.206559] ath: Country alpha2 being used: US
[   47.206560] ath: Regpair used: 0x3a
[   47.213125] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   47.222428] ieee80211 phy0: Atheros AR9280 Rev:2 mem=0x0000000055567a44, irq=93
[   47.423755] rockchip-i2s-tdm fddf4000.i2s: using zero-initialized flat cache, this may cause unexpected behavior
[   47.434130] wm8960 6-001a: supply DCVDD not found, using dummy regulator
[   47.434178] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.3.auto/input/input3
[   47.435027] wm8960 6-001a: supply DBVDD not found, using dummy regulator
[   47.442317] wm8960 6-001a: supply AVDD not found, using dummy regulator
[   47.447351] wm8960 6-001a: supply SPKVDD1 not found, using dummy regulator
[   47.449895] wm8960 6-001a: supply SPKVDD2 not found, using dummy regulator
[   47.610916] ath9k 0004:41:00.0 wlP4p65s0: renamed from wlan0
[   49.418059] EXT4-fs (mmcblk1p1): mounted filesystem 7ae33b74-fdb6-52ef-8cde-fa90ee137a19 r/w with ordered data mode. Quota mode: none.
[   50.266110] RPC: Registered named UNIX socket transport module.
[   50.267404] RPC: Registered udp transport module.
[   50.268518] RPC: Registered tcp transport module.
[   50.269589] RPC: Registered tcp-with-tls transport module.
[   50.270779] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   63.906110] rk_gmac-dwmac fe1b0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   63.909244] rk_gmac-dwmac fe1b0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-1
[   63.976659] rk_gmac-dwmac fe1b0000.ethernet end0: PHY [stmmac-0:00] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
[   63.990332] dwmac4: Master AXI performs any burst length
[   63.991747] rk_gmac-dwmac fe1b0000.ethernet end0: No Safety Features support found
[   63.994817] rk_gmac-dwmac fe1b0000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[   63.997945] rk_gmac-dwmac fe1b0000.ethernet end0: registered PTP clock
[   63.999434] rk_gmac-dwmac fe1b0000.ethernet end0: configuring for phy/rgmii link mode
[   64.904903] NET: Registered PF_QIPCRTR protocol family
[   77.055077] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[   77.059198] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[   77.758570] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[   77.768898] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[   77.769857] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  110.428779] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  110.433413] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  110.511354] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  110.530022] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  110.531064] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  118.728895] rfkill: input handler disabled
[  122.552725] rfkill: input handler enabled
[  123.996400] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  124.001756] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  124.101353] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  124.112014] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  124.113001] hdmi-audio-codec hdmi-audio-codec.6.auto: HDMI: Unknown ELD version 0
[  133.582637] rfkill: input handler disabled
[  134.474730] devfreq fb000000.gpu: Couldn't update frequency transition information.
[  150.855324] wlP4p65s0: authenticate with 04:f0:21:23:a9:3e (local address=04:f0:21:ac:1d:88)
[  150.856076] wlP4p65s0: send auth to 04:f0:21:23:a9:3e (try 1/3)
[  150.878000] wlP4p65s0: authenticated
[  150.882231] wlP4p65s0: associate with 04:f0:21:23:a9:3e (try 1/3)
[  150.884328] wlP4p65s0: RX AssocResp from 04:f0:21:23:a9:3e (capab=0x11 status=0 aid=4)
[  150.885362] wlP4p65s0: associated
[  156.642945] devfreq fb000000.gpu: Couldn't update frequency transition information.
[  179.851041] devfreq fb000000.gpu: Couldn't update frequency transition information.
I tested with:
  • SanDisk Extreme 32GB, MicroSDHC UHS-I, speed class 3, A1, Video 30
  • SanDisk Ultra 32GB, SDHC UHS-I, speed class |1| and (10, 120MB/s
  • SanDisk Edge 16GB, SDHC, speed class (4
The usual results of the first or second disk read benchmark:
If the benchmark works (sometimes happens first time you put an SD card, sometimes doesn’t) this is what it usually looks like, it instantly drops from 19mb/s (the common read speed) to 2mb/s.
I managed to pass a benchmark with the slower 16GB card, this is what it looks like (the second benchmark after this one instantly failed on start):
running kernel is 7.1.3-mnt-reform-arm64
So far this appears to be related to the kernel, since older kernels work fine. No idea why it seems to happen on my (and @max 's) R3.0, we both got them recently. It’s also strange how @josch can’t reproduce it. Are all R3.0 the same? (As in, they all use the exact same components or did something change in more recent batches?)((I know normally you would increase the rev number to something like R3.1 but maybe it was a very small change?))
I asked Lucie in the IRC channel and she said that there was no new batch of mainboards.
I would like to try harder to reproduce it. For example until your recent messages I didn’t know which benchmark you were running. I can try running the gnome disks benchmark myself (I didn’t do that yet). So to be sure: you flash the system image to sd-card, you boot that system and from that system (without installing to nvme first) you run the gnome disks benchmark?
Here is my collection of cards:
The one in the bottom center looks like yours:
Then I’ll focus my tests on that card. Can you confirm?
yes, the fullsize 32GB SDcard and the 32GB microSD you have are similar to the ones I tested with (The micro one failed the fastest but that might be because… it’s faster?). Write the mnt reform system image for RK3588-dsi (I use the .img.gz but I don’t think that matters) to one of them and try to get into GNOME and run the disks benchmark (on the disk not on the partition). First time might pass, second one should fail. Also if the reading speeds are around 2mb/s that’s also a warning something is off.
Btw even though my mnt reform is as recent as it gets, how do you tell when it is a DSI or an HDMI one? because the description in the handbook is a bit hard to visualize, I just assumed it was DSI because it is newer so I used this: Artifacts · build (#22099) · Jobs · Reform / reform-system-image · GitLab · MNT Source
Your classic Reform being “as recent as it gets” means that it’s the DSI variant. The very first units of RK3588 classic Reform were shipped with a HDMI->eDP adapter. But April 15 2025, Lucie figured out how to drive the mipiDSI->eDP converter with RK3588 and since then, the HDMI->eDP adapter board was no longer needed.
I tried again with exactly that card.
I used the RK3588-DSI image as well and used bmaptool to flash so that I don’t have to first download the whole thing. But yes, it doesn’t matter. The bits on the card in the end will be the same.
Do you see anything in the following screenshot which looks different from how it looks for you:
Also a long shot: could you try writing the image with a different SD-card writer? I have seen weird things happen with SD-cards before…
I have come up with new findings.
  • Some cards actually work perfectly fine, others fail instantly.
  • I wrote images on different computers with different adapters. It appears this affects how long they take to fail. Writing the SD card through a USB adapter in the MNT Reform seems to make the card fail almost instantly on boot. Writing it on a different computer seems to make them last longer before they fail (if you are booting from them for instance)
I tried different kernels including the previous one from a build from 7 months ago posted in this thread again. It failed too, so I really don’t know if it’s the kernel anymore.
Anyhow, to the left are the cards that never fail, to the right are the cards that always fail.
The pattern I followed goes like this:
  1. Run sudo dmesg | grep -E "I/O error|EXT4|Buffer I/O|blk_update"
  2. Check the output
  3. Insert an SD card into the SD card slot
  4. Run sudo dmesg | grep -E "I/O error|EXT4|Buffer I/O|blk_update" again (I don’t now how to do a tail -f to dmesg)
  5. If I/O Errors show up, the card is going to struggle to be read.
  6. Do a read benchmark on the disk with gnome disks to confirm (although other signs already make it obvious, like not displaying the partitions or showing that it has an Unknown filesystem). It will fail at some point.
So, possible causes:
  • The SD cards could be bad? I will test them on other computers but one of them (32GB) was purchased last week and it seems a bit odd.
  • Maybe the speed at which the SD card reader of the MNT Reform board expects the card to be is a bit specific? I don’t know where the controller for the SD card reader is, I have no experience with SOCs systems.
  • It does not seem to be related to the kernel? It’s hard to tell. Does the kernel running on the emmc u-boot affect the kernel inside the SD card you boot?
Here is the sudo reform-check of the configuration I ran these test under:
I: Contents of /proc/device-tree/model: MNT Reform 2 with RCORE-DSI RK3588 Module
I: `uname -a` output: Linux luzzy-mnt 7.1.3-mnt-reform-arm64 #1 SMP PREEMPT Debian 7.1.3-1+reform20260705T102633Z (2026-07-05 aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 7.1.3-1+reform20260705T102633Z
I: Version of reform-tools: 1.87-1+reform20260529T225830Z+1
I: Version of system image: System Image v5: 2026-07-06
I: Version of LPC firmware: MREF2LPC 30_R1 2351811
I: Version of upstream U-Boot: 2024.10
I: Version of MNT U-Boot: 2026-01-28
I: Mount source of /boot: /dev/mmcblk0p1 (eMMC)
I: the reform-qcacld2 package is only required for wifi on the Pocket Reform with i.MX8MP, you can safely remove it unless you plan to go back to the imx8m+
I: eMMC contains the latest bootloader version 2026-01-28
Also, a question about booting from USB. If you have already u-boot at the emmc pointing to boot the rootfs at the NVMe do you need to do something special if you just want to boot an image from USB? (assuming the USB has an u-boot partition + rootf partition, like the provided system-image)
So… in my hallway we have a professor who specializes on flash memory and according to him, SD-Cards are the worst flash memory on the market combining the cheapest no-name controllers with the cheapest no-name flash memory even when you buy brands like Sandisk or Samsung. I had this verified recently when I sent my SanDisk Sd-card that had died to a professional service to recover data from it and they told me the same story and told me that even though the card said “sandisk” it used a controller they had never seen before.
So, I believe that sd-cards can be bad but on the other hand – you have a 50:50 ratio there and that sounds much more bad than what my anecdotal evidence would allow.
Okay, so you have a system that is working fine from eMMC and SSD.
Maybe. It is rare that somebody wants to boot from USB. For RK3588, if I read the source correctly, then in include/configs/rockchip-common.h the boot order is:
#define BOOT_TARGETS  "mmc1 nvme mmc0 usb scsi pxe dhcp spi"
On the other hand, on imx8mq we have the order be first usb, then sd then emmc. I suspect usb got dropped because it was rarely used and takes up precious few seconds to initialize usb and mass storage devices on each boot with the screen being black and the user not getting any feedback on what is going on right now.
i see… I guess I could use the reform-boot-config to make the emmc boot the rootfs of the usb if I really needed to. But I don’t think I need to right now that I think I have some SD cards that should give no errors if I ever need to boot from them to rescue something. Also in the worst case, if these cards magically stopped working, I could get into the initramfs and wipe the boot partition of the emmc so that it tries to boot from USB I guess. Assuming initramfs has something like dd so that I can clear the emmc.
