Solving heat related issues with custom lid
After receiving my Pocket Reform, I noticed some heat-related issues. The main annoyances were CPU throttling and a sudden drop in WiFi speed at times. I suspected that the primary cause was the PCB lid. Although it has two copper layers, the insulating base material (FR4?) in between likely contributed to the heat retention.
My idea was to replace the lid with a simple aluminum plate. After discussing this idea with others on IRC, I felt a bit discouraged due to concerns about potential WiFi shielding. Nevertheless, I decided to give it a try.
To my surprise, it was a complete success. The temperature dropped significantly, and the WiFi remained functional. I decided to do some measurements to quantify the improvements.
I tested the WiFi speed with the different lids using iperf from the same position in the room (my desk). The temperature was tested by streaming a 1080p video on YouTube with chromium and hardware acceleration turned off.
The results were quite good. The temperature dropped by 30 degrees and the WiFi seemed to be even more stable than before. It appears that the plastic cover of the ports on the side is enough to allow the WiFi signal to propagate into the laptop.
I customized the lid by engraving it and spray painting it with UV reactive neon colors. The first prototype was a pure aluminum plate while the second one was a black powder coated one. Notably the coating had no impact on the temperature.
For the sake of completeness here are my testing conditions:
Test Video Norway - Youtube
Kernel: 6.10.9
Thermal pads (2.5mm) applied to CPU and WiFi chip: Amazon
Aluminum plate thickness: 1.5 mm
Link to the CNC files: On github
A big thanks goes to my boyfriend since he did most of the work and milled all the parts!
This is bad ass. And it looks super cool, too!
Wow, I tip my head to you and your boyfriend! I love that you collected and plotted the data to have some empirical data to draw a conclusion of your project. And I love to see all the photos you took and shared with us. Amazing project. It really stands out!
This looks incredible and now I really want to do something like this! I’ll have to look around for wicked CNC skills locally :slight_smile:
This was my redneck solution to the problem. I thought temps were pretty good with the banana pi cm4 but when I upgraded to the rk3588 I found the lid getting very hot. I had a bunch of heatsinks laying around from classic reform so I reused the heatsink from the cm4 kit and double sided taped it to the lid with some thermal compound underneath. I don’t have any pre or post graphs but system temp is around 45-50C at idle and seems to max out around 70-72C after playing Half-life 2.
Never feels too hot to touch.
I had a solid aluminum lid cnc’d by jlcpcb’s cnc machining service, cost me about $25-30 shipped, and I’m anxiously awaiting my pocket reform with the rk chipset to try it out on. I also got it engraved. I’ll be happy to provide the files once I actually get a test fit in, but the specs I had it machined to should (hopefully) fit. I’m hopeful of the performance given your benchmarks, thanks for the data points!
That sounds very exciting! Will JLCCNC countersink holes at that thickness? (I’ve looked at a few other services and it doesn’t seem to be an option for 1.2mm.)
This is really cool. Thanks for sharing.
How would one go about getting such a part made? I don’t really know anything about CNC manufacturing.
I can make a design in FreeCAD but then what? :slight_smile:
PCBWay, Xometry, and some others can do milling from CAD, with custom finishes. (If you make a plate in CAD please post the step files, I’d love to do this upgrade as well.)
A plate with full-width fins would probably reduce temps even more.
Edit: here’s a YouTube vid on how to go from 3D print to CNC part
Yes, they countersunk the holes for me. I just hope that a chamfer is enough to get the job done, part of why I’m hesitant to post the files just yet is I can’t test for fit, but I will as soon as I receive my pocket reform.
@pandora Wow. So cool. Thank you again for sharing!
I too have tried my hand at a little CAD and am waiting on an order from PCBWay. You can find my design files at GitHub - jbmorley/pocket-reform-backplate: Replacement aluminum CNC backplate for the MNT Pocket Reform. Just like @wytch I recommend holding off ordering using these until I can show it fits!
The nice thing about ordering with PCBWay is that they have a purple anodized finish, which I’m excited to try out with my purple Pocket Reform.
I put together a small post on my blog (December Adventure Day 16 — Jason Morley). The GitHub repo above includes the updated designs. :upside_down_face:
I’ve been satisfied with PCBWay. Messing with the files on KiCAD, I found a 0.9mm chamfer works well for the screws. 1mm left the heads a little recessed, which I didn’t like.
Looks absolutely stunning and great results!
Could this be an optional that MNT Research could offer directly through their website?? :smiley: Given not everyone will have such amazing partners…
This thread is cool to see! I’m eagerly awaiting follow up from those who ordered from JLCPCB and PCBWay :slightly_smiling_face: I wonder if a CNC bottom plate might also be nice for a more rugged device.
I’m totally planning a bottom plate too if the top one comes out OK. :crossed_fingers:t2:
That said, a gripe: when I went to go install the hardware on my new case parts, I found that they didn’t thread a couple of screw holes. Easy enough to fix.
Does it fit otherwise? Would you be willing to share your files? I’m also interested in this mod.
It’s made from the same files in the GitLab repository:
I only see STEP files from the outer case unless I’m overlooking them. The top and bottom plates are KiCAD so I assumed you had recreated them in STL or STEP. But it does look like FreeCAD can import KiCAD using an addon, is this the process you followed? I’m just trying to make sure I don’t inadvertently screw up conversion here somehow and order a bad part. From experience some CAD formats don’t always convert cleanly.
There are step files for my version in the repo linked above. I should have the part from PCBWay in my hands in the next couple of days and can post photos so you can see if it works for you.
