Hello everybody,
in the future it will be the new USB-C standard, if it is possible in the future to convert the connections to USB-C or an upgrade to that effect is planned.
I find it very convenient to use just one cable for everything.
What do you think? Or is it absolutely unnecessary? would require a motherboard change to force?
I think we’re going to be in a world of dongles for a while. My wife uses MacBooks, so I already have a bunch of USB-A to USB-C and USB-C to USB-A dongles around the house. It’s not ideal, but easier than replacing the motherboard.
Sorry for resurrecting old thread.
For me, advantage of USB-C is ability to use 1 cable to transfer data, video, and power to/from device. I don’t know however how much (re-)work of motherboard would it require, and how would it influence existing ports - HDMI, Ethernet, and ability to exchange CPU boards.
I have Purism Librem 13 laptop which has one simple USB-C port (only data, with neither power nor video) and I’m not using it often. Of course if there would be new motherboard USB-C port providing full-functionality (data, video, and power), I would be all for it. But as far as only adding data port - IMO it’s not worth the effort.
I prefer to keep power and data completely separate. I seriously dislike the fact that combining them provides potential attack vectors on the power connection, which in the case of USB-PD, is extremely difficult to mitigate.
