Whenever I have the wm8960 issue (wm8960 2-001a: Failed to issue reset), I can fix it by manually binding the wm8960 to the respective device:
echo 2-001a > /sys/bus/i2c/drivers/wm8960/bind
Worked reliably for me, maybe it helps someone.
