Something seems to be wrong with my Pocket Reform from August 30th.
I have a USB-C power supply that charges perfectly with -1A to -1.17A and 8.3V, as the OLED display shows me.
Charging in DE does not seem to be possible.
At around 42% the charge level drops to around -0.9A, at around 53% to around -0.06A.
I have already installed the update from August 26th.
Is this a hardware problem?
There is also a similar power drain problem when it is not plugged into the socket
Try letting the batteries drain all the way then charge it again. Citing this post Charging is extremely slow - #4 by minute
As for draining while idle I’ve been following this Battery drain issues/questions
Thanks for your help…
After It was running down for a while, it runs this Minecraft and a Youtube Livestream for more then 2 hours on 1%… until the battery was empty
I charged now to 100% and will see what the drain is saying in 8 - 9 hours.
So I’ve been having a similar thing and I tried letting it drain down and charge it back up a few times but all that’s done is let it charge back up to 46% instead of 38% and the odd thing is that I’m only getting like an hour and change of battery life total so I’m not even getting the “it stays at 2% for a million years” like above, it’s shutting down as soon as it ticks down to 2.
OK so there is probably a different issue now, which is upower (?) thinking it has to shut down the system when the battery is reportedly near 0%. We need to disable this temporarily, otherwise it’s not possible to calibrate the gauge. As far as I know, the upower service is responsible for this. Could you try:
sudo systemctl stop upower
And then let it drain, does that work?
Oh, hah, yeah one command and 5.5 hours of continual use later and it drained down to a hard shutdown and now it’s charging properly on up again.
@minute could the firmware maybe be changed such that userspace would think that the battery was much fuller than it actually is instead of thinking it is much more empty than it actually is? This is also an issue for the classic reform (remember the battery runtime benchmark by jeff geerling) where upower likes to shut down the device before lpc learned where zero percent actually is.
I would rather propose that we disable upower by default and people can enable it when they need it.
I’ve started to see my Pocket getting stuck at around a 53% charge and then not taking any more power in.
Reading this thread, it looks like the suggestion is to disable upower, fully run down to zero, and charge from there to recalibrate - is that correct?
Shouldn’t yours have already been calibrated by now?
Yes, this is the solution.
For the record, I didn’t disable upower (at least I don’t remember disabling it) and my battery has been calibrated correctly for a long time now.
Hmm. I’ve just done this process and my Pocket is still steadfastly sticking at 50% charge and going no further. (Reported by system firmware / OLED, which is current I think)
Any clues or things to investigate?
Is that happening only with a specific charger?
While not immediately helpful I can report that it took a couple times of me running the battery down before the thing calibrated completely. For a long while i could only get up to 95% instead off 100%.
Just keep using the device and it will eventually get there. ![]()
