I moved my Pocket to Bookworm, and as was mentioned wifi stopped working.
I was tipped off that @zeha knows how to get wifi working again, and I was hoping he could detail that here, for anyone else that might have the problem?
If he has the time and energy for it, thank you very much. If not, thank you anyway for all your contributions to MNT and Debian.
Yes I am using the i.MX8MP. I’m jelly of your RCORE. Really looking forward to moving my Pocket to it as well.
Basically, the network option is still in the waybar, but it fails to be able to connect to networks. I have 2 networks that are saved. It says these are available all the time, whether they are or not. If I force a disconnect, and then try to connect to one that is available manually, it will never connect.
For me, it was unable to move anything because directories were non existent. I just manually grabbed the latest qcacld2 file and installed it. Upon rebooting I see that I am on a different kernel. 6.11, whereas stable should be on 6.10-6 I believe. Not sure what is going on there.
I can either turn your post into a “wiki” post, so that others (with your approval) can edit it. But in general, this all should be fixed once the ezurio-qca-firmware package makes it through NEW as I’ve said in Debian/bookworm (stable) - #2 by josch
The official Debian stable kernel is at version 6.1 and it will only support imx8mq and ls1028 and also those two it does not support well. It needs a few MNT patches at which point it is not the “official Debian stable kernel” anymore. And this topic is about the Pocket Reform which does not work with kernel 6.1.
The kernel from reform.d.n that works with Pocket Reform is the kernel from bookworm-backports. And on top of that kernel, the reform.d.n machinery applies the MNT patches. Those patches are not really “backported” they are the same patches that are applied to the respective kernel version for the kernels in the MNT repo as well.
